What kind of numbers should i have?
I just bought an EG, and was wondering what kind of numbers i should be able to get out of it... Im planning on getting it dynoed and taking it to the track this spring, but was just wondering what I should HOPEFULLY expect out of it.
Engine
B16 head
Skunk2 stage 2 cams
BDL cam gears
Omni power springs
Omni power retainers
ARP head studs
ABES intake manifold
Thermal Intake manifold gasket
RC 310 injectors
Chipped ECU with data logging
I think that’s it??
LS block
Fresh honed
New OEM P30 pistons (11.7:1~ compression)
New OEM Oil pump GSR
New OEM Water pump GSR
ARP Rod bolts
Integra Type R transmission 97 spec LSD
Exedy Stage 1 organic clutch
Breathing/Cooling
Megan Racing header
2.25 exhaust (no cat)
Intake system
GSR radiator
Suspension
Tokico Whites 5 way adjustable struts
Comp Tech Lowering springs
Skunk2 camber kit
Energy suspension bushing kit
Braking
Full GSR four-wheel disk conversion
Drilled and slotted rotors
Any ideas, thanks.
Engine
B16 head
Skunk2 stage 2 cams
BDL cam gears
Omni power springs
ARP head studs
RC 310 injectors
I think that’s it??
LS block
Fresh honed
ARP Rod bolts
Breathing/Cooling
Megan Racing header
Intake system
GSR radiator
Suspension
Skunk2 camber kit
Braking
Any ideas, thanks.
