Ground short..Please help me out
Old Apr 4, 2008 | 01:50 PM
djmyst305's Avatar
Default Ground short..Please help me out
i have a ground short on the underdash fuse box #32 (ECM, TCM, Clock, Stereo Radio, maintenance reminder unit) which is also taking out my turning signals. the part in (...) is all that i am able to find. so where do i begin in fixing this issue? where does the wire run after the ecu? is there a spot where i can just replace the wire at both ends or what?
i am lost on fixing this issue.. and i got tickets for it, so i need to get it fixed within 25days now !! please help
Old Apr 4, 2008 | 05:44 PM
seskill's Avatar
Default Re: Ground short..Please help me out (djmyst305)
you need to go get the book on your car. and look at the diagram.
Old Apr 4, 2008 | 05:59 PM
lmike6453's Avatar
if it is a ground there are a lot of options here... if the ground is bad by the fuse box find the wire or socket that needs to be grounded and run a wire to the bottom left hand side bolt for the dash...
should be behind your hood latch area/behind the kick panel
I Love My 4 door
Dec 19, 2010 04:05 PM
el1cuban
Dec 27, 2008 06:18 PM
DIRTYsouthBB6
May 3, 2006 07:42 PM
xstalkrx
Apr 12, 2003 12:21 PM
importfan85
Sep 21, 2002 12:47 PM
