Engine Problem that i cant figure out, help please!
Old Apr 4, 2008 | 12:52 PM
blue89hatch's Avatar
Default Engine Problem that i cant figure out, help please!
well i recently swapped a d16z6 in my 89 civic hatch 4 days ago and it ran good so far
on the interstate today it died on me. so i started it again while i was coasting and then i started hearing this rattling and clanking sound under the hood and my car started to over heat and run rough, then i lost complete power and it bogged down and died
I noticed the timing was off so i redid the timing and it started up but still a clanking sound and some rattling, so i checked the valve adjustment and it was all correct, and i looked at my timing again and somehow it managed to be way off again. im not sure whats goin on? or if maybe im about to throw a rod,
Any help would be appreciated alot! thank you
Modified by blue89hatch at 2:13 PM 4/4/2008
Old Apr 4, 2008 | 03:31 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Engine Problem that i cant figure out, help please! (blue89hatch)
rotating assembly could be seizing/could have a bolt/object stuck behind timing belt covers, etc
Pull off timing covers and inspect. While the belt's off, see if the crank spins relatively easy, same with the cam
Old Apr 4, 2008 | 04:13 PM
Default Re: Engine Problem that i cant figure out, help please! (Evs-One)
i got the timing to stay the same now, but the car is overheating quickly and there is a clanking sound and i checked there is nothing inside the cover,
Old Apr 4, 2008 | 06:31 PM
Evs-One's Avatar
Solbros Owns Me
could be a bad rod knock- how's oil pressure/oil level/sediments in pan, etc?
overheating could be related or could be a separate issue- head gasket, t-stat, bubbles, etc
Old Apr 5, 2008 | 01:11 AM
EJ1B18c's Avatar
could be your bottom end bearings. same thing happened to me with the same engine. took sump off and found a lot of copper/lead material. the knock sounded like it was comming from the head.
riotchild
Sep 26, 2011 01:23 PM
96 EX
Oct 1, 2008 11:47 AM
blue89hatch
Apr 5, 2008 05:05 AM
yc_dc4mar
Jan 25, 2007 11:11 AM
sinister6
Jul 20, 2004 05:33 AM
