Springs that don't drop much?
I'd appreciate if you guys could help me choose some springs, here's what I'm looking for:
Info: Car is 98 ek hatch, shocks are koni yellow
Drop: I want as little drop as possible. (not more than 1.5-2")
Spring rates: 450f/400r or something close to that.
In other words, I need an almost race setup that doesn't drop too much,
Which springs should I go for?
Thanks
Thanks
Buy some Ground Control coilovers (Koni Shock specific) with the spring rates your looking for. <~ That way you can adjust the height to whatever you'd like!
https://honda-tech.com/zerothread?id=1224090
^^this may help with the spring rates..
may be kinda hard to find a spring at that rate that doesn't drop much because most racing springs have at minimum a 2in drop. your best bet would have to be full coil overs... or settle for the softer spring like the tein s-tech and have adjustable dampers set to the stiffest setting. that is what i am running right now on my hatch, s-tech's with agx's at the stiffest set
Modified by ATLianIntruder at 2:34 PM 4/4/2008
hmm, thanks for the link, didn't know the neuspeed race were that stiff. I'm starting to lean more towards the Neuspeed race, only if I could see a pic of their drop... It says 2"-2.2" which should be fine for winter time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_ej8 »</TD></TR><TR><TD CLASS="quote">look into h&r sports.</TD></TR></TABLE>
Thats what I'm thinking, I like the rates and they don't drop too much.
Tony R
Apr 2, 2004 05:56 AM
