What are acceptable knock volts? ...
Old Apr 4, 2008 | 07:59 AM
BlowenGT's Avatar
Default What are acceptable knock volts? ...
I've been doing some logging and I'm getting a voltage spike of 3.4volts that lasts for 1 second and drops to 1.7 after.
At the spike the log show:
Knock volts 3.4
Engine load 154.5
Engine speed 8613
O2 10.87
Ign timing 17.45
Air temp 19.4
Another log with more timing and warmer temps showed:
Knock volts 3.1
Engine load 151.7
Engine speed 8699
O2 11.56
Ign timing 20.26
Air temp 28.4
Should I be pulling back timing in that one particular cell?
How sensitive is the stock knock sensor, could I be picking up false knock?
Should I be worried? Any input would be great as Im just learning...
Basic setup info:
02 s2000
InlinePro kit
Aem ems/wideband
Magnified
Old Apr 4, 2008 | 04:17 PM
stumpyf4's Avatar
Default Re: What are acceptable knock volts? ... (BlowenGT)
You'll find that the stock ECU ignores the knock sensor signal over a certain engine speed (i think 4000rpm) since the sensor does not produce accurate results at high RPM.
However I'd try pulling some timing and seeing if it makes a significant change, if not it's 'probably' not knocking.
BlowenGT
Apr 3, 2008 03:10 PM
honda616
10
May 15, 2007 01:30 PM
untitledsn41
Jul 30, 2004 04:48 AM
SC0TT
Apr 24, 2002 11:52 AM
