ATI Street damper. Aluminum or Steel hub???
Old Apr 3, 2008 | 09:06 PM
Bond's Avatar
Default ATI Street damper. Aluminum or Steel hub???
Well i have searched and searched with not to much info regarding my question; which is a good thing in a way lol. My question is with the ATI street damper (street version with alt. a/c and removable p/s pulley) is made with an aluminum hub. now my only concern would be that it's not steel (possible key wear on the softer aluminm hub?) The race version (only alt pulley) is also offered in an aluminum and steel hub. i think i have come to the conclusion that the aluminum hub is used to lighten the damper and does not effect the overall strength. i'm not sure so i though i would ask. any info, experience with the street ATI damper, or things you have heard; would be great if you could share. thanks
Old Apr 19, 2008 | 12:21 PM
rebo0t's Avatar
they're pressed onto the crank and uses the oem key/bolt. as long as you got it on right dont worry about it.
cksnah252
45
Feb 16, 2015 06:51 AM
portenio78
Jul 30, 2011 01:51 PM
His_Dudeness
Sep 2, 2010 06:11 AM
A2gt35r
Nov 2, 2007 04:26 PM
Innovation
37
May 27, 2005 10:46 PM
