Replacing oil seal
Old Apr 3, 2008 | 08:11 PM
Ritchie's Avatar
Default Replacing oil seal
I was wondering how do you replace the oil seal near the cam gear. Do I have to remove the cam itself in order to get it out? Tried searching but nothing shows what I'm trying to find. Thanks.
Old Apr 3, 2008 | 10:54 PM
r1lsr's Avatar
Default Re: Replacing oil seal (Ritchie)
if you talking about the cam seal, you do have to remove the cam shaft mounts. there should be individual ones on each pillars. just remove the one that the seal is on and thats it, put everything back together, but remember to not over torque the botls.
Old Apr 3, 2008 | 11:04 PM
Ritchie's Avatar
Default Re: Replacing oil seal (r1lsr)
So only time to remove the bolt from the cam gear is when everything is bolted down, right? By the way, is it possible to reuse the seal or is it recommended to change to new ones?
hondacivkev
Jul 9, 2011 11:09 AM
endlssmystry
Jan 24, 2010 08:11 PM
BoostRetard
Jan 8, 2006 12:12 PM
Austin
Jul 26, 2005 08:14 PM
