car shakes at 50mph, about to drive it into a wall!!!!!!
i have a 94 ls. the suspension is bone stock. had the car looked at by acura techs and they cant figure out why my car shakes. the axles are 2 month old. the rotors are not warped (just resurfaced them). and the dealer said all my ball joints and tie rods were ok. they did say that the trailing arm bushing were kinda shot but that the shake i was getting shouldnt be from them. they obviously werent that bad. they also told me that maybe it was the tires so i went and bought some different wheels and tires, made sure they were balanced properly and to no avail, still the same shake. i doesnt get better or worse depending on how much throttle i give it, turn either way, or brake. it always stays the same. im about to kill this car. never had this much trouble with it before and it feels like its gonna fall apart on the freeway. please help before i just start throwing parts at it.
I had a delsol and put some advance auto axles on it and when i would get on the freeway i thought it was going to hope off the ground sometimes lol, but i went to honda got new oem axles and never had the problem agian.
ended up the subframe had a few loose bolts. about half of them made a half to full roation to tighten. seems like it went away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixster »</TD></TR><TR><TD CLASS="quote">ended up the subframe had a few loose bolts. about half of them made a half to full roation to tighten. seems like it went away.
Jack the car up, check to see if your wheels have any play in them. If any do there is your culprit, can start troubleshooting from there. Can be a number of things
