MY FOGS ARE IN WTIH PICTURE
MY EBAY FOGS
I HAVE A PROBLEM THAT IS THE TOP SIGN ON THE FOG IS AT THE BOTTOM BUT NOT TOP.
I TRY FLIPPING THEM BUT STILL NO LUCK.
I KINDA WENT TOO HAPPY WITH THE DRILL AND SAW THOUGH CUTTING WAS A BITCH TO DO.
ANY1 HAD THIS PROBLEM BEFORE WITH THEIR EBAY FOG?
OH ONE MORE QUESTION I TRY TAKING THE BULB OUT BUT IT WON'T BUDGE.
Modified by immajackuup at 3:56 AM 4/4/2008
I just got my ebay fogs in too. And yeah, I too had that top and bottom issue. the light pattern seems unaffected by it so I don't care. I was surprised to see how cheap they really were lol. The screws were the best part of it. They didn't skimp out on those! And it didn't come with instructions but I figured it out. I'll post mine up soon. I havn't tried taking out the bulb, however. What type does it use?
they use h3 bulb.
I just want to buy h3 piaa because the bulb they give me aren't bright enough.
they are bright but not enough for my taste
i was thinking of doing hid in my fogs, but the only problem i be running in to is how I'm going to get the wires and plug out of the back plate.
i guess i drill a big hole or something?
Yeah the my ebay fogs were flipped around too haha kinda threw me off for a little and i did the same thing with the drill on one side of mine too. O well u cant even tell when looking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b »</TD></TR><TR><TD CLASS="quote">what makes this bumper so much diff from a 97 bumper it looks the same to me...</TD></TR></TABLE>
96-98 is a completely different bumper than 99-00. The 96-98 doesn't have the holes on the sides to mount the foglights posted in this thread.
I just used the reference marks on the OEM bumper. I thought it was too big but everything fit fine. It was actually too small, I need to enlarge it so I can later replace bulbs and make adjustments without having to remove the bumper.
https://honda-tech.com/zerothread?id=2061530
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">No, definitely not.
If you want '99-'00 headlights, you're going to have to swap all of the following:
- Headlights
- Upper Grille
- Fenders
- Hood
- Front Bumper
The you have to replace or modify your core support. If you just modify it you might also need to cut notches into the top of the front bumper.
Notice the big differences in the front ends. The shape of the headlights, the shape of the bumper, the shape of the hood, the shape of the fenders, the shape of the grille, the height of the grille, the width of the grille, the round headlight corners, the more pointed inner headlight corner, the space between the headlights and the grille...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">'96-'98 front end
'99-'00 front end
- Headlights
- Upper Grille
- Fenders
- Hood
- Front Bumper
'99-'00 front end
shadohconspiracy
16
Sep 14, 2007 11:25 AM
