headlights dont work on 2000 em1
Old Apr 3, 2008 | 05:11 PM
1sikcoupe's Avatar
Default headlights dont work on 2000 em1
hey guys my low beams dont work on my 2000 si but my high beams do work any ideas on what i could do to fix this? are there fuses for the low beams in the under dash fuse box?
if anyone can help that be great
Old Apr 3, 2008 | 05:16 PM
cherroneballs's Avatar
yeah fuses I don't know if there under the dash or engine bay though
Old Apr 3, 2008 | 05:23 PM
EFRue57's Avatar
Default Re: (cherroneballs)
it's a dual element bulb maybe the low beam elements are blown.
Old Apr 3, 2008 | 05:27 PM
1sikcoupe's Avatar
Default Re: (EFRue57)
i checked the fuse that says headlights in the fuse box in the engine bay i just wanted to know if theres fuses for the headlights under the dash ? also i had hid 's on my car took them off now my low beams no longer work?
Old Apr 3, 2008 | 05:28 PM
1sikcoupe's Avatar
Default Re: (1sikcoupe)
and i repleace the bulbs with working ones
Old Apr 3, 2008 | 05:30 PM
EFRue57's Avatar
if you took the hid's off then did you mess with any wiring? if so then just double check what you connected/disconnected.
Old Apr 3, 2008 | 05:34 PM
1sikcoupe's Avatar
no didnt mess with anything , put a new set of bulbs on probly hook up and no low beams ? i lost my diagram for my under dash fuse box thats y im wondering if theres a high / low beam fuse in the box, also other than fuses what other possible problems can it be
Modified by 1sikcoupe at 4:02 AM 4/4/2008
Old Apr 3, 2008 | 07:02 PM
1sikcoupe's Avatar
bump
Old Apr 3, 2008 | 07:15 PM
EG8R's Avatar
Sorry I'm no help for location for the fuse but I am pretty sure there are seperate fuses for high and low beam. If I were you I would just start pulling out fuses one at a time and look for blown ones.
Old Apr 3, 2008 | 07:59 PM
ifIexplode's Avatar
https://honda-tech.com/zerothread?id=1966666
There is seperate fuses for High and low beams.
As well as left and right headlight.
Above is a link to Underhood and Under dash Fuse boxes.
Old Apr 4, 2008 | 02:24 AM
1sikcoupe's Avatar
Default Re: (ifIexplode)
thanks guys im gonna check out the fuses and get back to u guys
not-a-stang
Apr 9, 2008 07:50 AM
jimboek
Apr 30, 2007 05:22 AM
DC231 Sean
Jul 27, 2004 07:49 AM
TypeR 508
Apr 22, 2002 09:44 AM
GettaluvR
Aug 3, 2001 05:22 PM
