headlights dont work on 2000 em1
hey guys my low beams dont work on my 2000 si but my high beams do work any ideas on what i could do to fix this? are there fuses for the low beams in the under dash fuse box?
if anyone can help that be great |
yeah fuses I don't know if there under the dash or engine bay though
Re: (cherroneballs)
it's a dual element bulb maybe the low beam elements are blown.
Re: (EFRue57)
i checked the fuse that says headlights in the fuse box in the engine bay i just wanted to know if theres fuses for the headlights under the dash ? also i had hid 's on my car took them off now my low beams no longer work?
Re: (1sikcoupe)
and i repleace the bulbs with working ones
Re: (1sikcoupe)
if you took the hid's off then did you mess with any wiring? if so then just double check what you connected/disconnected.
Re: (EFRue57)
no didnt mess with anything , put a new set of bulbs on probly hook up and no low beams ? i lost my diagram for my under dash fuse box thats y im wondering if theres a high / low beam fuse in the box, also other than fuses what other possible problems can it be
Modified by 1sikcoupe at 4:02 AM 4/4/2008 |
Re: (1sikcoupe)
bump
Re: (1sikcoupe)
Sorry I'm no help for location for the fuse but I am pretty sure there are seperate fuses for high and low beam. If I were you I would just start pulling out fuses one at a time and look for blown ones.
https://honda-tech.com/zerothread?id=1966666
There is seperate fuses for High and low beams. As well as left and right headlight. Above is a link to Underhood and Under dash Fuse boxes. |
Re: (ifIexplode)
thanks guys im gonna check out the fuses and get back to u guys
