How do i replace my boot?
Old Apr 3, 2008 | 02:48 PM
JesseBizz's Avatar
Default How do i replace my cv boot?
can someone tell me step by step after the wheel, caliper and rotors off
its a civic si 96 (Si In canada)
ASAP >_<
Modified by JesseBizz at 3:55 PM 4/3/2008
Old Apr 3, 2008 | 04:48 PM
xunsungheroesx's Avatar
Default Re: How do i replace my cv boot? (JesseBizz)
I just got a new axle. I looked at the service manual and it seemed tons easier to replace the whole axle than it was to remove and reinstall the inboard joint so that you can replace the boot. I especially preffered not having to clean out and repack the boot grease.
Old Apr 3, 2008 | 04:57 PM
Kurly's Avatar
Default Re: How do i replace my cv boot? (xunsungheroesx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xunsungheroesx &raquo;</TD></TR><TR><TD CLASS="quote">I just got a new axle. I looked at the service manual and it seemed tons easier to replace the whole axle than it was to remove and reinstall the inboard joint so that you can replace the boot. I especially preffered not having to clean out and repack the boot grease.</TD></TR></TABLE>
x2
is there any damage to the boot/axel? why are you wanting to relpacing the boot?
info please..
Old Apr 3, 2008 | 04:59 PM
Jakester9500's Avatar
i would have to agree as hell, just replace the axle. you'll thank yourself later
Old Apr 3, 2008 | 07:52 PM
mugen si's Avatar
Default Re: (Jakester9500)
ya...alot of the time, the whole complete axle and boots arent that much more if buying from a prts store. plus alot less work! you need to pull the axle nut off, pop the lower ball joint, take off the damper fork(holds the shock and spring up). get everything out of the way. your then going to have to pry the inboard joint away from the trans to get it to pop out remember that you might need to lightly tap the end of the axle in to free it from the hub. And you dont need to take the caliper or rotor off to do this
Old Apr 3, 2008 | 08:37 PM
hard_boiled_EG's Avatar
Default Re: (mugen si)
i got bored one day and decided to disassemble an old d-series axle...one the side that goes into the transmission came off pretty easy, but the side the goes into the rotor...whole different story, it took me a vice and a nice big hammer and half an hour...i don't think i would trust using that axle anymore...
oldskoolDA6
Jul 9, 2009 11:39 AM
athoughts
16
Sep 27, 2005 12:49 PM
gtowni3
Dec 24, 2004 08:09 AM
calean
Nov 10, 2004 06:04 AM
clean
Nov 2, 2001 12:04 PM
