Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
In car camera mounts? Post 'em up!
Old Apr 3, 2008 | 12:07 PM
xci_ed6's Avatar
Default In car camera mounts? Post 'em up!
I'm thinking of building one for my car (no roll bar/cage), and I have what I think is a good idea. It is always easier to copy a proven design though.
Anyone have one that works well?
Old Apr 3, 2008 | 02:10 PM
clem kevin's Avatar
i just built one yesterday!
C-pillar bar - 15$ shipped
2 U-bolts with washer type things, 3$
Plate of sheet metal 2$
Free vacuum hose in my friends garage
Nuts found in old tin cans
only things left are mounting the actual camera (ill be cutting a large bouncy ball in half to use as a kind of damper for the camera to sit on) and finding a washer to replace the thickness of the seatbelt clips since the brackets on the bar didnt work with them.
here you have it....
Old May 4, 2008 | 04:43 PM
xci_ed6's Avatar
Default Re: (clem kevin)
built my own yesterday and tested it out today. Worked great!!
it's 3/4" square tube steel, drilled for the headrests and I built in a little clamp, so it actually clamps onto the headrest bars. The camera is mounted on a hinged plate that has a thumb screw to adjust the angle up & down to correct for seat back angle. Also has a eyelet for bungee cords that are then hooked to the seat brackets to take out vibration. I'll post up some vids when I figure out how to get them off the camera.
Old May 4, 2008 | 08:12 PM
liam821's Avatar
25 Year Member
Default Re: (xci_ed6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xci_ed6 &raquo;</TD></TR><TR><TD CLASS="quote">
it's 3/4" square tube steel, drilled for the headrests and I built in a little clamp, so it actually clamps onto the headrest bars. The camera is mounted on a hinged plate that has a thumb screw to adjust the angle up & down to correct for seat back angle. Also has a eyelet for bungee cords that are then hooked to the seat brackets to take out vibration. I'll post up some vids when I figure out how to get them off the camera.</TD></TR></TABLE>
That looks like it would chop your head off in an accident.
Old May 4, 2008 | 10:58 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (liam821)
Old May 5, 2008 | 06:30 AM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
That looks like it would chop your head off in an accident.</TD></TR></TABLE>
uh...how?
Old May 5, 2008 | 07:32 AM
liam821's Avatar
25 Year Member
uh...how?</TD></TR></TABLE>
I wouldnt want a bar that wasnt screwed or welded to the frame of the car directly behind my neck. Just my $0.02 cents.
Old May 5, 2008 | 03:15 PM
eflove's Avatar
mine. it was cheap.
Old May 5, 2008 | 03:50 PM
Weston's Avatar
Two exhaust clamps, a strip of 1/8" thick aluminum, some rubber washers, and a cheap mount...
The results were decent: video here
I believe that the small amount of shakyness you see is from the cheap mount's adjuster not tightening down all the way (I'm going to upgrade to the one from $14 tripod from BestBuy), and a lack of rigidity in the mounting point on my camera.
Modified by Weston at 6:13 PM 5/5/2008
Old May 5, 2008 | 04:24 PM
xci_ed6's Avatar
I wouldnt want a bar that wasnt screwed or welded to the frame of the car directly behind my neck. Just my $0.02 cents.</TD></TR></TABLE>
The headrests go through the bar, and it is clamped down, for it to chop my head off the headrests would have to shear off. That means something would have to directly hit the bar, in which case i would be dead anyway.
If I had a cage in the car it would have been way easier to come up with a mount for sure, or if ebay had c-pillar bars for accord sedans.
Old May 5, 2008 | 07:24 PM
gabebauman's Avatar
Old May 7, 2008 | 08:42 AM
nicokpe's Avatar
Nice built
Old May 7, 2008 | 10:00 AM
Pompiuses's Avatar
Default Re: (nicokpe)
My old teg with camera mount from Ioport Racing.
Video came out like this:
http://video.google.com/videop...75477
Old May 7, 2008 | 10:02 AM
gabebauman's Avatar
Default Re: (Pompiuses)
Nice...did you make the pillar bar?
Old May 7, 2008 | 10:07 AM
Pompiuses's Avatar
Default Re: (gabebauman)
I bought it from http://www.ioportracing.com. I got the square in the middle welded in though.
Old May 8, 2008 | 08:22 AM
Hayasa15's Avatar
i like the headrest mounts. i was thinking of hacking up a headrest to do something similar but just use the frame of the headrest.
Old May 8, 2008 | 05:55 PM
Outrun's Avatar
Default Re: (Hayasa15)
92-95 Civic headrests aren't great for those neat little headrest mounts.
Old May 8, 2008 | 08:09 PM
DEIVIONCRX's Avatar
Default Re: (Outrun)
Old May 8, 2008 | 08:24 PM
Wendys or Bust's Avatar
Whats the thread pitch for the bolt that hold the camera? Is it a universal thread pitch?
Old May 8, 2008 | 08:28 PM
DEIVIONCRX's Avatar
Default Re: (Wendys or Bust)
pretty sure its universal, i just took the camera to the hardware store.
Old May 8, 2008 | 09:59 PM
02 accord's Avatar
1/4-20
Old May 8, 2008 | 10:13 PM
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">1/4-20</TD></TR></TABLE>
your awesome
Old May 8, 2008 | 10:38 PM
89civicdx's Avatar
^If you don't have a cage or rollbar you should try a suction cup camera mount.
Also I totaly don't understand what stops the bar from rotating forward besides the tightness of the seatbelt bolts? I see the belts are now mounted on the bar so when you pull on the belts...the bar rotates forward? The belts should still be mounted to the bolts...just my thoughts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by 89civicdx at 12:09 AM 5/9/2008
Old May 8, 2008 | 11:57 PM
Pompiuses's Avatar
Default Re: (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">
The bar is locked from rotating by the nuts in each end of it. It's designed for having the seat belts this way. Check out the webpage I linked to.
Old May 9, 2008 | 05:44 AM
89civicdx's Avatar
Hey I checked out the page but your pictures are better than thier pics lol. silly ioport
I know it has locking nuts on the bar...I meant up at the seatbelt bolt...the 17mm? 19mm? What stops the mounting plate from rotating forward? Like there are nuts on those bolts?
