big problem, no starty
I went out to my car today to start her up, and it wouldnt start. It just makes a funny clicking noise, like a rapid click. Anyone know whats wrong with it? Or any suggestions, im bummed out.
do the cheap fixes first....
1. you tried jump starting
2. next is make sure the battery terminals are tight and not corroded, give them a good cleaning and make sure they're tight at the other end too. after cleaning, you may need to try jumping it again.
3. now you're down to spending money, it's either the starter (more likely) or battery (yes I have seen jump starting fail when the battery is so bad that it sucks all the juice from the "donor" car and doesn't allow any to go to your starter
4. another possibility is the main relay, but that usually doesn't make a clicking sound... it's just dead when that's out.
hope this helps
hope this helps
rapid clicking = battery
one click = starter
Clean and tighten battery terminals, then do the same on the starter connections. Turn off radio, lights, etc when trying to start the car.
one click = starter
i was having this same problem a coupe days back. change youre ground wire from the battery and also change the posative that should fix youre problem and it will only cast around 20 bux. peace
more fun and you get a work out
