dont know what to do with the motor
Old Apr 3, 2008 | 09:24 AM
effg714's Avatar
Default dont know what to do with the motor
new at this stuff so plz bear with me.......my ef has been sitting on my drive way for months and trying to get it back and running.....so i believe i blow up the motor cuz i took off the vavle cover and found two broken intake spring retainers....so what im trying to get info on is what could of caused this? how bad would the damge be? would i have to do rebuild on the whole motor or just the head? and how much money am i looking at?
http://img517.imageshack.us/img517/7769/006gr4.jpg
http://img147.imageshack.us/img147/1465/007cb6.jpg
http://img147.imageshack.us/img147/4519/010pf9.jpg
http://img147.imageshack.us/img147/2249/008ed2.jpg
Old Apr 3, 2008 | 10:57 AM
h22crxpwr's Avatar
Default Re: dont know what to do with the motor (effg714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by effg714 &raquo;</TD></TR><TR><TD CLASS="quote">new at this stuff so plz bear with me.......my ef has been sitting on my drive way for months and trying to get it back and running.....so i believe i blow up the motor cuz i took off the vavle cover and found two broken intake spring retainers....so what im trying to get info on is what could of caused this? how bad would the damge be? would i have to do rebuild on the whole motor or just the head? and how much money am i looking at?
http://img147.imageshack.us/img147/2249/008ed2.jpg </TD></TR></TABLE>
you won't know the extent of the damage until you remove the head. it could have dropped the valve into the cylinder and bounced around. or it could have just broken and dropped it slightly. if you are magically lucky you might just be able to run it still with new springs and the damage might be minimal, but you would have to be VERY lucky, most likely it dropped the valves into the cylinder, if your lucky again it just trashed one or 2 pistons and didnt damage the walls too bad.
Then you can go 25 over pistons and re-bore and hone. the head if you are lucky didnt get too banged up from the valve. sometimes it just makes a few marks which you can live with. other times it lodges the head of the valve in the chamber!!!
the only way to tell how bad the damage is, is to remove the head..
Did the sparkplugs come out in one peice? were they hard to remove?
Old Apr 3, 2008 | 01:42 PM
effg714's Avatar
Default Re: dont know what to do with the motor (h22crxpwr)
i havent tried to take out the sparkplugs or attempt to take the head off but will do so by this weekend
Old Apr 3, 2008 | 08:21 PM
effg714's Avatar
so i took off the spark plugs and found spark plug nearest to the dist. was broken and saw broken metal inside the spark plug whole, im assuming its the piston but the other three spark plugs were easy to take out and where in good condition
effg714
Apr 3, 2008 08:32 PM
chiguagua
Jun 16, 2007 12:36 PM
honda_tuner10
Oct 14, 2006 10:49 PM
Dunc
Jun 6, 2005 11:06 PM
RAS Motorsports
Sep 23, 2003 09:16 PM
