Advancing timing with 9.0:1 compression....
Old Jul 10, 2002 | 10:01 AM
X2BOARD's Avatar
Default Advancing timing with 9.0:1 compression....
I am running a (roughtly) 9.0:1 compression forged piston in my LSVT with stock header. I will be running this setup for a month or two while I save some fundage... the problem is that 9.0:1 in a 4dr is slower than the snail I used to have.....
I want to advance my ignition timing and was wondering what would a safe advance would be... especially considering the low compression.
Also, without advancing timing....what would the lowest octane gas I would be able to run ? 89 ?....ooooh.... 87 ??
Old Jul 10, 2002 | 11:23 AM
pub's Avatar
pub
Default Re: Advancing timing with 9.0:1 compression.... (X2BOARD)
You can run 87 Octane without advancing the timing with that compression. I think that's even the the owners manual for a B18B for a 10:1 CR.
Old Jul 10, 2002 | 12:20 PM
X2BOARD's Avatar
Default Re: Advancing timing with 9.0:1 compression.... (EVIL Teken)
I would assume that I can either run 87 octane with stock timing OR 92/3 with advanced timing. Would I also correct in assuming that if I advance timing to 16-18 degrees, that I MUST run at least 92 octane or would I be ok with... hmmm... an 89 oct considering my low CR ?
Thanks for the responses thus far
X2
Old Jul 10, 2002 | 12:31 PM
X2BOARD's Avatar
Hmm... 18 deg (on which octane ? Any? The highest ?) I am running NGK 7 plugs from my turbo setup (not on right now), should I run a colder plug ?
But I think I need to re-adjust my fuel pressure. I currently have it set at about 38 or so *pinched*
I am looking to get one of 2 things.... either a bit more power to push the turtle along OR Crazy-MaDD-SkILLz gas Milage.
buffgsr
Jun 6, 2010 12:30 PM
1.8T_EG
Apr 29, 2003 04:46 PM
turbodsmpower
Apr 12, 2003 05:55 PM
HX_Guy
Nov 2, 2001 11:38 AM
