Washer / bolt trick to fix rear camber (94-97)! I Need details!!
Old Jul 10, 2002 | 09:48 AM
Fuster_Cluck's Avatar
Default Washer / bolt trick to fix rear camber (94-97)! I Need details!!
Ok, I have heard from a few people now that the rear camber can be adjusted on the 95 Accords using the longer bolts and adding washers trick. I did this on my 98 Civic and just wondering what bolts you use and which ones are replaced. It was two bolts with my civic that connected the control arm to the chasis of the vehicle. Just like in the picture:
I need to know what bolts (exact sizes) and where the bolts are located on the car.
Thanks a lot!
PS <> The coilovers are in and riding good!
Old Jul 10, 2002 | 09:59 AM
p0pe's Avatar
Default Re: Washer / bolt trick to fix rear camber (94-97)! I Need details!! (LX98Civic)
http://www.jdmfan.com/technical/suspension/rear_camber/
Old Jul 10, 2002 | 10:04 AM
John's Avatar
New User
01GSR has photos of his washer camber kit install. Unfortunately, he's on vacation, so do a little searching.
Old Jul 10, 2002 | 10:13 AM
Default Re: Washer / bolt trick to fix rear camber (p0pe)
Ok, I know how to do the civics camber. I did mine and have plenty of pics of the adjustment.
Did you post that link for the civic because it's the same?
That will be nice if it is the same >>> VERY easy task to handle!!
Thanks!
Old Jul 10, 2002 | 10:21 AM
-RedneckDave-'s Avatar
Working
Default Re: Washer / bolt trick to fix rear camber (LX98Civic)
hope those work out for your brother alright
Old Jul 10, 2002 | 10:35 AM
p0pe's Avatar
I was pointed to that page by 01GSR (i think) when I asked about this.. I'm guessing it should be very similar.
lil k
May 19, 2003 12:22 AM
roydogg
Dec 5, 2002 08:06 PM
dellman177
Oct 3, 2002 06:59 PM
.brad
Sep 9, 2002 11:41 AM
fcuked
10
May 8, 2002 09:18 PM
