where are you mounting you after market gauges?
Well after buying my s2000 ive came to notice that it is a real bitch to put more then 3 gauges in the car.
i have two on the A pillar and a wideband in the corner by the windsheild, those all fit just fine with no obstructions.
NOW with this build i will running
4 egt gauges
1 oil temp gauge
and possibly a water temp gauge.
That make 9 gauges WTF am i going to put this ****.
last resort in the dash going across it. So let me have some pics of where i should put all this stuff.
4 egt gauges
1 oil temp gauge
Why would you even want that many gauges? And why would you even possibly need all of them. 4egt gauges? It's like you just want a light show in your car.
i take it you're runin' a single egt gauge per cylinder... kinda a lot don't you think?
the only way is to mount them on the pass. dash area, which unless done correctly, will look like ****.
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 »</TD></TR><TR><TD CLASS="quote">i take it you're runin' a single egt gauge per cylinder... kinda a lot don't you think?
i agree... you def have to be precise with measuring and drilling... even an 1/16th of an inch off and itll look like ****... my advice to you is mark up everything in pencil, buy stickers that are roughly the same size as your gauges and do several mock ups... the last thing u want is to have 4 guages looking like jaws mouth...
more like i dont want another blow up engine. the IM on the s2000 sucks *** and under boost cyl do not get even amounts of air, some more then others. in the end it will get a safer tune. i have seen first hand 4 of these engines run lean melting the # 1 cyl.
and yes one probe per cyl. not 4 egts in one lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 140sx »</TD></TR><TR><TD CLASS="quote">for sure, if i do it that way it will look clean. no way around it</TD></TR></TABLE>
im a genius... i just had a pretty good idea... measure the rear diameter of the guages then go on the computer and make the same diameter circle, copy all 4 of them in a line and equally spaced... now u have a template which you can cut out the holes and then use to mark up the dash...
for me
for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA »</TD></TR><TR><TD CLASS="quote">
for me</TD></TR></TABLE>
**** il drink to that
not to bad il have to see if i can get it to print now. lol
for me</TD></TR></TABLE>**** il drink to that
can't argue with that
graf-fiti/s2killa '08
"abuse we can believe in"
for me</TD></TR></TABLE>can't argue with that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">
"abuse we can believe in"</TD></TR></TABLE>
great campaign... i bet u we could get atleast 10,000 votes... we'd have to be totally radical... legalize marijuana, lower the drinking age, and legalize prostitution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. »</TD></TR><TR><TD CLASS="quote">http://www.ricks2k.com/products/gaugeset.php</TD></TR></TABLE>
POS for $1200, such a ripoff.
total garbage.
to the idiot who buys one.
total garbage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. »</TD></TR><TR><TD CLASS="quote">http://www.ricks2k.com/products/gaugeset.php</TD></TR></TABLE> wouldnt you want the gauges to be in good view so your not looking down to see ****... mount them on the dash it works best
i mounted mine in front of my wind screne so i can see them in the rear view mirror. i also have two down near my pedals, 1 in my shift ****, and 1 in my left air vent. i feel like i am in a aircraft or a fighterjet
just be gangsta like the 240sx guys qand just say [freak] vents...fill every vent up with a gauge. then you would be tru jdm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K »</TD></TR><TR><TD CLASS="quote">i mounted mine in front of my wind screne so i can see them in the rear view mirror. i also have two down near my pedals, 1 in my shift ****, and 1 in my left air vent. i feel like i am in a aircraft or a fighterjet
that's stealth mode
a+ for creativity
that's stealth mode
a+ for creativity
</TD></TR></TABLE> take a photo you little ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote"> take a photo you little ****
i cant...it is my design I WILL NOT SHARE
</TD></TR></TABLE>i cant...it is my design I WILL NOT SHARE
Id say buy SPA GAUGES. They are 2 gauges in 1. You would be able to get 6 gauges in 3 spots. You dont need any more than that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jefferyg32 »</TD></TR><TR><TD CLASS="quote">Id say buy SPA GAUGES. They are 2 gauges in 1. You would be able to get 6 gauges in 3 spots. You dont need any more than that.</TD></TR></TABLE> do you really think most people need 6 gauges? even if your turbo you really only need boost and oil psi maybe one other for oil temp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jefferyg32 »</TD></TR><TR><TD CLASS="quote"> You dont need any more than that.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote"> do you really think most people need 6 gauges? </TD></TR></TABLE>
hahaha
hahaha
the more you have the more jdm yo. when i boost i will have atleast 15 gauges in various colors to represent my jdm gayness.
