vtec LED mod
I visited this site & i think it pretty explanatory on the mod. However, I've seen some other sites recommending to buy something like a "330 ohm resistor." Do i need to buy this for this mod? It doesnt mention anything like that on the website I viewed.
I'll be using a 12V LED, and prob a 16g wire. Other than that, I'm not sure what else I need to know. I'm not sure how much current will be put out..
Does it matter?
You can tell electricity isn't my "thing." Help me out with this, Muffin!
Does it matter?
What LED are you using? Getting one online? Link me to it and I can tell you what resistor you'd need.
*edit*
If you were to buy these:
http://cgi.ebay.com/20x-Blue-L...wItem
A 1/4W 470Ohm resistor would be more than enough and would dim them a bit too since they'd come bright as hell (to clarify more) you can using a 330ohm resistor would be fine too.
Modified by TheMuffinMan at 1:18 AM 4/3/2008
*edit*
Something like this.
http://www.radioshack.com/prod...earch
And can you clarify for me what a resistor actually is/does?
Well your purpose of putting one in would be to prevent a voltage or current spike going through and killing the LED.
If you go to your car you can see it ranges around 12V but really isn't ever exactly 12V.
The resistor just resists the flow of current
Alright, well that is the LED im planning on using. That will work correct? How difficult is it to install a new resistor? And what exactly connect it to? Do i connect it to the wire right by the VTEC solenoid, and then connect the 16g wire to the resistor?
Also, I have tons of left over copper speaker wire, prob about 18 or 16g, would this wire work so I dont have to purchase all the other wire? Let me know!
What resistor should i look for?
http://www.radioshack.com/sear...&sr=1
16 gauge is fine.
If you get the radio shack LED (that exact one)
Pick up a 330ohm resistor 1/4W
You really only need a 230 but they don't make those haha.
Wire it like this:
power ------resistor----- (+) led
ground --------------------- (-) led
The + is the longer of the two legs.
You really only need a 230 but they don't make those haha.Wire it like this:
Would the copper wire that is used for stereo and speakers work fine for this job?
& i wont need to do any soldering, will i?
Modified by tpot90 at 10:34 PM 4/2/2008
Multiple strands? This is like the wire I have.
Will that not work? Can't I just wrap the wiring around everything and use electrical tape to keep it together?
..Assuming soldering is out of the question.
What do you mean by the quick connects? Are you talking about the caps that twist around 2 wires and connect them?
Soldering is really not a priority of mine, I dont want to buy a gun, either. I just want this done. I'll manage to make the wrapping acceptable for my taste.
Just tell me how i can do this. & Will that wire i showed you in that link work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 »</TD></TR><TR><TD CLASS="quote">What do you mean by the quick connects? Are you talking about the caps that twist around 2 wires and connect them? </TD></TR></TABLE>
he means this: http://www.eclipsetools.com/Pr...7.JPG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 »</TD></TR><TR><TD CLASS="quote">I'll manage to make the wrapping acceptable for my taste. </TD></TR></TABLE>
I recommend buying shrink tubing. Its only $3... and it looks clean!
The wire in the link should work, wire is wire for the most part.
The soldering however would only cost you $15 or so , 10 for an iron and 5 for a spool of solder. And you wouldn't have to worry about stuff coming loose.
jonesEK
12
Dec 18, 2010 12:53 PM
Jizzmaster Zero
Sep 29, 2005 03:43 PM
