Please HELP!!!! My 1999 Honda Accord keeps burning thru cats
Ok heres a good one. I have a 1999 Honda Accord 4cyl VTEC. It has burned thru its second cat in 2 months. Car is running great. Its not flashing any codes either. Any help would be greatly appreciated. Please help.
From: living too close to Karl, everythings busted, nc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcarpenter3d »</TD></TR><TR><TD CLASS="quote">Ok heres a good one. I have a 1999 Honda Accord 4cyl VTEC. It has burned thru its second cat in 2 months. Car is running great. Its not flashing any codes either. Any help would be greatly appreciated. Please help.
If it has no codes nor check engine light, how do you know it has a bad cat? Did you go aftermarket or oem?
</TD></TR></TABLE>If it has no codes nor check engine light, how do you know it has a bad cat? Did you go aftermarket or oem?
I had my local muffler shop install an OEM cat on both occasions. When a cat goes bad sometimes it will start to rattle loudly. Mine was doing that when I had the first replacement installed. My muffler shop told me that if my car was running to rich (hot) that it would burn up the fiberglass in the cat causing the ceramic plates inside to rattle around. Its quite loud and annoying. If it is running too rich im not sure where to start looking. Its not flashing any codes and I recently cleaned my egr port due to a previous error code (EGR Innsuf. Lift detected). Once I cleaned the port and I also replaced the factory air filter with a K&N it started running alot better (more responsive) but it was still burning up cats.
Are you using tabby cats or another breed ?
The rattling might actually be a heating shielding down there, you could just have them remove it. I think you may be overreacting to the cats. Are you sure there aren't any other issues down there?
