Parts to fix a sloppy shifter, pic inside
Old Apr 2, 2008 | 11:08 AM
MotoCARR's Avatar
Default Parts to fix a sloppy shifter, pic inside
Wondering if I have the correct parts picked out, and if not, can someone point the numbers out that I would need to correct a sloppy shifter? Is the bitch pin #6 in the pic? I have read a few people using a different bolt to correct the problem. Would that be #29 and #25?
Old Apr 2, 2008 | 11:18 AM
GSR CRX's Avatar
Default Re: Parts to fix a sloppy shifter, pic inside (w8lifter21)
#33 is the bitch pin. all #25 and #29 do is hold shifter onto the shift linkage. improving shifter feel would all be in the bushings such as #18 an #20.
Old Apr 2, 2008 | 11:25 AM
MotoCARR's Avatar
Awesome, thank you sir!
Old Apr 2, 2008 | 12:07 PM
crx-si's Avatar
For a sloppy shifter those bushings usually don't go it is the bushings in the bottom of the shifter that usually are the problem, 4,5,6,28,15, or just get a short shifter for an easy fix.
Old Apr 2, 2008 | 12:25 PM
glagola1's Avatar
In my experience, it's usually the universal joint in the linkage it self that wears out.
I got a new "16" and bam. Super tight.
Old Apr 2, 2008 | 12:40 PM
MotoCARR's Avatar
I really only have experience with eBay shifters. What short shifters come with the necessary bushings? I'm always down for another mod!
Old Apr 2, 2008 | 12:59 PM
KazzaF's Avatar
Default Re: (w8lifter21)
Skunk2 with es bushings kit. just installed it on my civic. Feels awesome
Old Apr 2, 2008 | 02:32 PM
solorex's Avatar
Default Re: (glagola1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glagola1 &raquo;</TD></TR><TR><TD CLASS="quote">In my experience, it's usually the universal joint in the linkage it self that wears out.
I got a new "16" and bam. Super tight.</TD></TR></TABLE>
X2 It's usually not the bushings...
Old Apr 2, 2008 | 03:37 PM
harmonator84's Avatar
Default Re: (solorex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KazzaF &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 with es bushings kit. just installed it on my civic. Feels awesome</TD></TR></TABLE>
This is what is next on my list of items to get. I want the dual bend!
Old Apr 2, 2008 | 05:03 PM
grog's Avatar
You should just get under the car and start moving the shifter around, then you should be able to see exactly whats wrong.
X2, I've been wanting to replacing/rebuild mine for a while now. I was planning on drilling out the rivets and replacing the "rods" with bolts. Also I have heard Hasport sells a U Joint rebuild kit.
glagola1, what are you refering to in your post, new 16?
Old Apr 2, 2008 | 05:48 PM
schardbody's Avatar
i would like to add that 2 of the 13 hondas i have owned have had bolts in the bitch pin location, this caused a very loose shifter on both.
Old Apr 2, 2008 | 06:00 PM
hondasaurusrex's Avatar
Default Re: (schardbody)
i've got a bolt in the bitch pin position, and i can tell ya right now that my shifter is sloppier than a hooker from the red light district, and im fixing it ASAP...dont use a bolt regardless of what you do to fix the problem
Old Apr 3, 2008 | 04:30 AM
MotoCARR's Avatar
So the bitch pin slides into the hole that's on the right side of #16? That pin keeps it in the knuckle?
Old Apr 3, 2008 | 04:57 AM
Disco Monkey's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote"> glagola1, what are you refering to in your post, new 16?
he is talking about a new shift linkage which is #16 in the picture.
i think that joint is also the cause of my sloppy shifter.
Old Apr 3, 2008 | 05:02 AM
zccr-xsi's Avatar
Default Re: (KazzaF)
thats i got is the es shifter bushings and my shifter feels good too.
es bushing make a world of differance.
Old Apr 3, 2008 | 05:03 AM
PuroMotor's Avatar
Is that #16 your referring to in the picture?
Im gonna try this out because my shifter is so loose i cant get into gears sometimes.
Old Apr 3, 2008 | 05:05 AM
94accordsedan's Avatar
Banned
What Matt said, just get a new part #16 in the picture and you'll see a world of difference.
Old Apr 3, 2008 | 07:52 AM
gringo7718's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">I've been wanting to replacing/rebuild mine for a while now. I was planning on drilling out the rivets and replacing the "rods" with bolts.
Yes, you have to use the correct size hardware so there is no play and use a locking nut. This setup also makes it easy to disconnect the shifter bars (no need to remove bitch pin)
https://honda-tech.com/zerothread?id=2032639
I want to do this but I have not personally done it YET
Modified by gringo7718 at 5:00 PM 4/3/2008
Old Apr 3, 2008 | 08:18 AM
1989CivicSi's Avatar
Default Re: (gringo7718)
Don't forget to replace #10 while you're at it if you're still running the original 20 year old unit. Mine is loose as hell.
BDM
Sep 24, 2009 02:16 AM
ketchup
Aug 19, 2008 08:58 AM
vwtohonda
Aug 7, 2006 08:55 AM
eluder33
Nov 20, 2004 03:05 PM
