swap a 92-95 single cam si motor to a 96-up ek???
Old Apr 2, 2008 | 05:32 AM
south_sac_red_ek's Avatar
Default swap a 92-95 single cam si motor to a 96-up ek???
the company "boomslang" makes harnesses to convert obd2 to obd1. . . and i was wondering is it going to be a hassle to swap my ek 96-up to a 92-95 single cam si motor??? has any one did this swap??? can u guys tell me what the essentials to do this swap???
Old Apr 2, 2008 | 05:51 AM
Probot's Avatar
Default Re: swap a 92-95 single cam si motor to a 96-up ek??? (south_sac_red_ek)
use the search button, these swaps are done almost frequently and have been covered numerous times.
Old Apr 2, 2008 | 09:05 AM
blk92_d16's Avatar
Ecu harness adaptor, dizzy adaptor, and a couple other little wiring issues. Was your EK a vtec model Civic?
Old Apr 2, 2008 | 10:10 AM
Default Re: (blk92_d16)
no my ek is a 96 dx model.. .. ..
Old Apr 2, 2008 | 10:48 AM
1990 crx dx b's Avatar
Default Re: (south_sac_red_ek)
Get the whole harness, ECU, and such for the Z6. If you wanna save yourself the trouble (considering your bottom block is fine and you don't really care about how much "better" the z6 oil pump flows), do a mini-me y8 head on the d16y7 block and wire it for VTEC and its basically the same thing except for the transmission ratios.
rx7turbo287
Jul 8, 2017 05:28 PM
pmpate
Oct 6, 2016 03:43 PM
d1nki
May 3, 2006 08:11 PM
HybridEL
Mar 8, 2005 05:18 AM
pbsis
Aug 27, 2004 04:20 PM
