JDM Front Conv. Connecter (4 pin)
Old Apr 2, 2008 | 12:38 AM
Alvieh_R's Avatar
From: Autobahnland, A96/A99/A92/A9/A4 - 255 kph ITR speed, and itīs legal!
Default JDM Front Conv. Connecter (4 pin)
Hello
Does anybody know or have plan how have to connect the 4 pins from the connector? There are also 5 pin connectors, i think they are for the HID Headlights. But I have the halogen ones and we couldnīt get the high beams going.
We got the city lights and fog lights (yellow) working with the first step of the light switcher. Second step is normal - it puts the low beam on.
But if I pull the switcher, then the blue light on the cluster comes on, but now high beams.
BUT: the headlight flasher works if all the other lights are off (step 0 on the switcher)
Can anybody pls help me?
greetings from germany
Old Apr 2, 2008 | 03:27 AM
sheekdude's Avatar
Default Re: JDM Front Conv. Connecter (Alvieh_R)
Make things easy on yourself...
http://passwordjdm.com/Passwor....aspx
Hope this helps...
Old Apr 2, 2008 | 04:29 AM
R.Kelley's Avatar
I wanna say you need the 5 pin. this is all off the top of my head but I want to say that the Fog, city light, and high beam all run off the same ground. just figure out what color the high beam power wire is in the JDM light.
Old Apr 2, 2008 | 09:57 AM
Spids5's Avatar
Don't judge or question
Default Re: (R.Kelley)
The 5 pin connectors are if you have HID headlights. Also did you wire up the fog lights with the fog light switch and a relay? That is the right way to do it, you don't want them just coming on every time you turn your lights on. Here is a write-up on how to wire the fog lights and and should help you to wire up the high beam.
https://honda-tech.com/zerothread?id=2195061
Old Apr 2, 2008 | 10:10 PM
Alvieh_R's Avatar
Default Re: (Spids5)
Thank you very very much.. i think this will help.
But: Yes, we made so as i want it: Switch Step 1 -> city lights & yellow fog lights *insane look O_O*
B-B-K
Oct 28, 2007 07:30 PM
Speedraca01
Jan 19, 2006 07:47 PM
intekragsr
Jan 14, 2006 12:31 AM
[Ennis_D]
Jan 11, 2005 06:50 AM
Screamer
Aug 3, 2001 03:11 PM
