Transmission keeps revving even in Neutral. WTF.
Old Apr 1, 2008 | 07:08 PM
atefcrx's Avatar
Default Transmission keeps revving even in Neutral. WTF.
I have a 97 civic with stock d16y7 engine and tranny. I was merging onto the freeway shifting from one gear to the next, when shifting from 4th gear to 5th gear my car starts to redline hard core. I put it in neutral and the car was still red lining. I am going to change the clutch on Thursday and I wanted to make sure that the clutch was the problem. My hatch is my DD so I need to get it up and running asap. Any help would be greatly appreciated, I thank you in advance.
Old Apr 1, 2008 | 07:10 PM
csulliva's Avatar
What would make you think that had anything to do with the clutch?
Sounds like a stuck throttle.
Old Apr 1, 2008 | 07:14 PM
m0nee's Avatar
Default Re: Transmission keeps revving even in Neutral. WTF. (atefcrx)
It's definitely not a clutch issue. Throttle stuck open is a possible cause.
Old Apr 1, 2008 | 07:18 PM
atefcrx's Avatar
Default Re: (csulliva)
I just got the car in Sept. started driving it in January and the car felt like clutch was going out. I checked the throttle cable to see if it was stuck and it seemed to fix the problem then when I started the car again and stepped on the gas the car kept revving and redlining. ?
Old Apr 1, 2008 | 07:21 PM
csulliva's Avatar
because you have a sticking throttle. You unstuck it, then got it stuck again as soon as you stepped on the gas.
Old Apr 1, 2008 | 07:29 PM
atefcrx's Avatar
How do I go about fixing this?
Old Apr 1, 2008 | 07:35 PM
m0nee's Avatar
Default Re: (atefcrx)
lube, grease, something of that sort!
Old Apr 1, 2008 | 07:36 PM
waynecoSI's Avatar
clean your throttle body, clean the spring that your cable connects to, new cable. my dd civic did this because my cable was phucked. it was dry and snapped. try cleaning it a bit
Old Apr 1, 2008 | 07:40 PM
atefcrx's Avatar
Default Re: (waynecoSI)
THanks for the advice guys.
Old Apr 1, 2008 | 07:41 PM
waynecoSI's Avatar
wd40 is great
Old Apr 1, 2008 | 09:21 PM
katyruff's Avatar
bump
Old Apr 1, 2008 | 09:44 PM
7601chexplicit's Avatar
thats a pretty nice hatch....its insane that the owner was about to drop the tranny to change the clutch, over the throttle getting stuck, lol
Old Apr 1, 2008 | 11:06 PM
atefcrx's Avatar
Default Re: Transmission keeps revving even in Neutral. WTF. (7601chexplicit)
The clutch still needs to be swapped. Thanks for your 2 cents.
Old Apr 2, 2008 | 09:48 AM
blk92_d16's Avatar
The TB plate inside could be sticking...I'd use carb cleaner on the inside, not WD-40. Check for cable binding check that the cable adjustment nut is tight against the IM bracket. GL on the trans drop! find someone to help yah with that.
Old Apr 2, 2008 | 09:52 AM
1990 crx dx b's Avatar
Default Re: (blk92_d16)
CLEAN OUT YOUR THROTTLE BODY. Spray the spring mechanism with some sort of lubricant.
Old Apr 2, 2008 | 01:14 PM
atefcrx's Avatar
Default Re: (1990 crx dx b)
Broken accelerator cable. Fixed already. thanks to all who steered me in the right direction.
Old Apr 2, 2008 | 01:21 PM
motorD16Y7's Avatar
for honda-tech
Old Apr 2, 2008 | 03:43 PM
m0nee's Avatar
you still doing that clutch?
Old Apr 2, 2008 | 03:47 PM
csulliva's Avatar
nice, glad it was the cheap solution.
Old Apr 2, 2008 | 04:26 PM
atefcrx's Avatar
Default Re: (m0nee)
Thursday night I am doing the clutch
Old Apr 2, 2008 | 04:29 PM
atefcrx's Avatar
$22 from H&A Auto in Westminster.
teg969
Jul 21, 2008 01:07 PM
MCP486
Jan 13, 2003 03:43 PM
[626]95-GSR
Aug 11, 2002 12:24 AM
hybrider
Aug 3, 2002 06:20 PM
[626]95-GSR
Feb 15, 2002 02:52 AM
