vx block with d16z6 head. timing belt help
Old Apr 1, 2008 | 06:52 PM
argenis111's Avatar
Default vx block with d16z6 head. timing belt help
hi my bottom end got mess up on my civic ex. so i got me a d15z1 block and i'm using the d16z6 head. as far as i now i have to use the d16z6 timing belt, i just want to comfirm that.
please help
Old Apr 4, 2008 | 09:46 PM
Biggmike92vx's Avatar
Default Re: vx block with d16z6 head. timing belt help (argenis111)
pm'd
Old Apr 5, 2008 | 05:17 PM
argenis111's Avatar
Default Re: vx block with d16z6 head. timing belt help (Biggmike92vx)
well looks like nobody knows what timing belt to use..............VX uses a small timing belt than the EX. i found out yesterday when i did my setup VX block EX head.
the point is not on the belt is on the tenssioner, VX has a smaller gap where the bolt goes so it has less space to adjust.
you can use any timing belt aslong as you use the same tenssioner
for example.
d16z6 belt with d16z6 tenssioner
d15z1 belt with d15z1 tenssioner..........all water pumps are 19 teeth..
Old Apr 5, 2008 | 05:20 PM
ddd4114's Avatar
The rule of thumb is to use the timing belt that is designed for your head.
Old Apr 16, 2008 | 07:10 PM
fearthis4's Avatar
Have you looked at what your compression is going to be with that head and block combo? http://www.c-speedracing.com/h...c.php
About 7.8:1 lol Idk how that's going to work out... you might do a little better if you used a d15b7 or an old d16a6... but unless you change those pistons your going to be running like
Old Apr 16, 2008 | 07:11 PM
fearthis4's Avatar
Default Re: vx block with d16z6 head. timing belt help (fearthis4)
Maybe just get a VX head...? that's what my buddy is running now...
Contender25
12
Sep 12, 2011 01:36 PM
eg6_trust
Apr 2, 2011 02:36 PM
ssl2k
Jun 9, 2005 12:02 PM
ssl2k
Feb 24, 2005 11:16 AM
SleepyHF
Apr 1, 2004 06:47 PM
