Anyone hear a noise after installing aftermarket springs on your CRX?
Old Apr 1, 2008 | 05:38 PM
klion22's Avatar
Default Anyone hear a noise after installing aftermarket springs on your CRX?
I installed KYB shocks and Eibach Sportlines in my 91 HF. And when i drive it, i hear clanging noises from my rear suspension when i hit a bump. As if the springs aren't seated properly. Anyone else notice this? If so, is it normal? If not, what can i do to fix it? Do i need to replace the spring rubber mounts perhaps which hold the springs?
Old Apr 2, 2008 | 10:00 AM
Marc_H's Avatar
Default Re: Anyone hear a noise after installing aftermarket springs on your CRX? (klion22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klion22 &raquo;</TD></TR><TR><TD CLASS="quote"> As if the springs aren't seated properly. </TD></TR></TABLE>
Just check if the springs are sitting properly like you said , It happen to me whit my skunk2 springs because they are shorter than stock , so when you drop the car down make sure they are sitting correctly or it will make noise
Old Apr 2, 2008 | 01:50 PM
klion22's Avatar
Default Re: Anyone hear a noise after installing aftermarket springs on your CRX? (Marc_H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marc_H &raquo;</TD></TR><TR><TD CLASS="quote">
Just check if the springs are sitting properly like you said , It happen to me whit my skunk2 springs because they are shorter than stock , so when you drop the car down make sure they are sitting correctly or it will make noise </TD></TR></TABLE>
Actually, i already did that. Twice. It's weird. Maybe it's not the seating but rather the upper rubber mount which holds the upper part of the spring. Are the springs supposed to be attached to the upper rubber mount or not because i think mines are and maybe that's why the bottom part of the spring gets lifted up and down during bumps.
guero2craze
Suspension & Brakes
12
Apr 29, 2007 02:30 AM
Wazup
Suspension & Brakes
Jan 27, 2006 01:49 PM
KingJeff
Jul 25, 2004 12:49 PM
pitbull
Jun 27, 2004 06:01 AM
94HybridEX
12
Apr 29, 2003 07:06 PM
