Has anyone seen a "factory" chipped ecu? does it exist?
well, i received this ecu in a partial payment for a socketed ecu, broke it open to socket it and find this:
upon further checking, it looks factory, this solder job is incredible, just like all the other factory parts, and uses the factory resistors and jumpers. was just wondering if anyone knew anything about this? also, its a 94 automatic P28
MORE pix:
MORE pix:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">I see them all of the time.
I bet you do
but you run through ecu's like I run through jimmy hat's.
I've seen these before on Pgmfi.org. but never in person.
</TD></TR></TABLE>I bet you do
but you run through ecu's like I run through jimmy hat's.I've seen these before on Pgmfi.org. but never in person.
The one pictured above is USDM. They did this when they used the ECU in a different vehicle than the programmed processor was intended for. Also when there was a change done to the firmware after the processor had already been programmed. As you can see here, this processor was originally intended to be used in a P05, but it went into a P28, so they had to use the external program access (AKA chipping) to make the firmware match the hardware.
FortunateFool.
Jul 10, 2005 07:03 PM
