EP3 cluster in a CRX?
Anybody think it will fit?
I know the LS, GSR integra clusters fit under the 90-91 cluster covers, and so do the 99-00Si clusters. And Ive seen a EP3 clusters in an EK... Like here:
http://youtube.com/watch?v=y4j...lated
well, the RSX cluster has a similar shape to the del sol type of cluster, where the left and right side hang down, almost in a U shape.
it can be made to fit but would require cutting, and something pretty custom to cover it all once done, and you lose half the guages on the left and right side.
the EK clusters however, are the correct shape, and fit fine. i used to run a 98 manual non SI cluster in my last cr-x.
also lots of people have swapped the Si cluster from the EK years as well.
as far as the EP3 cluster, you need to see the shape of one first, then do a quick side by side to make sure it isnt like 3 inches taller then the EF one.
wiring wise, it shouldnt be too hard.
this is the type of cluster that really doesnt work:
im trying to find an image of an EP3 cluster pulled out....
