Is it worth it to hide the brain here? Where to splice?
Old Jul 10, 2002 | 05:37 AM
Undepelo's Avatar
Default Is it worth it to hide the brain here? Where to splice?
Is it worth my time and effort to hide the brain somewhere in the rear side pannels (probably will protect it with plexiglass if I put it back there) or do I just remove the dash and find a spot there? BTW my car is currently striped except the dash. I do want to make a good install and will take my time but i was wonderingg if the extra effort is practical. Also, where do I splice into my ignition I-III/a/c heater etc.. so it's difficult to hotwire. I was thinking it must be easy for a thief to just rip the splices and reconnect the wires if it's accesible but where ISN'T it accesible? Sorry for the dumb questions. TIA
Old Jul 10, 2002 | 06:25 AM
ME's Avatar
ME
Default Re: Is it worth it to hide the brain here? Where to splice? (Undepelo)
If you can hide it in the dash that will be easier for you. So long as the brain inaccessible without a lot of disassembly that's fine. The rear is a pain because you'll have to extend some wires. It's up to you, from a security standpoint the rear is best but the biggest thing is not up under the driver's side dash.
Old Jul 10, 2002 | 06:53 AM
Undepelo's Avatar
Default Re: Is it worth it to hide the brain here? Where to splice? (ME)
But is there really an inaccessible area in the dash? I can see far into it's areas pretty easy so I guess a slim hand can reach and yank it out. Anyone have ideas?
Old Jul 10, 2002 | 03:42 PM
ITACivic's Avatar
I am an old Circuit Shitty shop manager. Alarms a good deteurrents, but they cannot stop the real theives. I tried to stay away fro starter kill install. I tried to talk them out of it. Why, because they only screwed up the car owners. If the alarm unit was a normally closed ingition kill, then it was not so bad. If the alarm malfunctions with a normally open starter kill, then the owner could not start the car and drive over to the shop and yell at me. But to answer your questions, just install it under the dash in a hard to get to place. I cut the ignition wires at the steering column. Do you know how to spin the wires for a clean and easier install?
Old Jul 10, 2002 | 06:59 PM
GSRaCeRbOI's Avatar
Default Re: Is it worth it to hide the brain here? Where to splice? (ITACivic)
lolz don't you just use a drill to spin the wires together?
anyways if you want to go through all the trouble of running all the wires to the back then coo... or you can just put it under the dash where its not easily accessible/where you ahve to take off a bunch of panels to get to it.. not sure how your CRX is.. never had one.. so I can't suggest places...
[Modified by GSRaCeRbOI, 8:07 PM 7/10/2002]
Old Jul 11, 2002 | 07:48 AM
ITACivic's Avatar
Default Re: Is it worth it to hide the brain here? Where to splice? (GSRaCeRbOI)
yes you can use a drill to spin the wires.
Old Jul 11, 2002 | 02:15 PM
nsxxtreme's Avatar
Spun wires means easy to spot!
I used all black wires hid the alarm in a secret location not under the dash, and extended the wires. I also ran all the wires in the stock wiring harness, I did not make any connections at the dash. Just remember if you extend the wires you may have to use larger wire on some of the wires. Like the ignition kill for example, will need larger wires if extended.
Old Jul 11, 2002 | 11:22 PM
philly-O's Avatar
Default Re: Is it worth it to hide the brain here? Where to splice? (nsxxtreme)
a killer place to put the brain in your dash is behind the glove box next to the a/c unit, or since the car is stripped you said just pull the dash out (its only like 10 screws/bolts) and then do your alarm. you could also do an ignition kill or fuel kill with your starter kill relay, or use one of your outputs to trigger the kills.
k2.4
Acura TSX
May 19, 2008 06:07 PM
ALL IMPORT
May 3, 2008 08:40 PM
Gaspar_06_Civic_EX
Honda Civic (2006 - 2015)
10
Jul 10, 2006 10:22 AM
gianinline
Oct 16, 2005 08:03 PM
