wheel bearings reusuable?
Old Apr 1, 2008 | 03:00 PM
huge230's Avatar
Default wheel bearings reusuable?
Can front wheel bearings be pressed out and then pressed back into a different set of knuckles?
Old Apr 1, 2008 | 03:30 PM
NJIN BUILDR's Avatar
Default Re: wheel bearings reusuable? (huge230)
The inner race usually end up stuck to the hub when you press it off.Plan on using new bearings.
Old Apr 1, 2008 | 04:19 PM
huge230's Avatar
Default Re: wheel bearings reusuable? (NJIN BUILDR)
if that happens then the bearing is no good anymore? Ive never worked with wheel bearings before
Old Apr 1, 2008 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">if that happens then the bearing is no good anymore? Ive never worked with wheel bearings before</TD></TR></TABLE>
Yes.The race is almost impossible to get off the hub without destroying it.I have heard of people pressing them apart to install longer studs and press them back together.The bearings started to make noise and needed to be replaced shortly after.
Old Apr 1, 2008 | 05:36 PM
huge230's Avatar
ok thanks for the info
Old Apr 1, 2008 | 05:38 PM
PI$TOL's Avatar
* B A N N E D *
yep plan on doing new bearings. like NJIN said they usually fall apart and maybe you can put it back but its gonna prematurally wear out.
76 camaro car
Jan 19, 2015 09:28 AM
jerowo
Oct 9, 2009 06:16 AM
thunderboy
Mar 20, 2009 12:15 PM
immalooser
Feb 28, 2006 12:44 AM
ViZ
Feb 11, 2005 07:52 PM
