special question about speed sensor!
Old Jul 10, 2002 | 03:33 AM
austrian type-R's Avatar
Default special question about speed sensor!
Is the speed sensor of the R limited or something? Lets say I drive 190mph, deas he still show and read the the correct value of speed?
Old Jul 10, 2002 | 03:35 AM
Reid's Avatar
Global Moderator
Default Re: special question about speed sensor! (austrian type-R)
Yes, but the stock speedometer is inaccurate.
Old Jul 10, 2002 | 03:49 AM
Default Re: special question about speed sensor! (Reid)
What yes? I know it is inacurate, therefore I have the Apexi AVC-R which is hooked up to the speed sensor, but does the speed sensor read 190 mph or is he damgaged?
Old Jul 10, 2002 | 05:15 AM
Reid's Avatar
Global Moderator
Sorry I wasn't clear, the speed sensor is not limited.
Old Jul 10, 2002 | 05:17 AM
cool, thx!
Old Jul 10, 2002 | 05:18 AM
Dr Pooface's Avatar
Sorry, this is OT but OMG 190mph?????? You are crazy.
Old Jul 10, 2002 | 05:26 AM
Default Re: special question about speed sensor! (Ddub)
Here is why I want to know about the speed sensor
Top speed vs AutoX TRANNY on 430bhp turboed ITR
I don' t know what to do.
I droved on the Autobahn for a Topspeed run with 4 people in the car (including me) and I maxed out at 265 kph indicated. From 200 - 265 it was such a RUSH, it took about 10 seconds I guess. This was with 1.2 Bar of boost, 608 mm tire diameter and 8800 revs (cut off)
Tranny is stock (we have JDM 4.785 final drive)
I can convert to USDM final drive (I have it at home already) to get a top speed for about 290 kph. But I will lose about 300 rpms for AutoX, which is not so good I think (for turbo lag).
I can convert to LS 5th gear for Top speed about 295, but this cost again money.
Perhaps converting to a larger finaldrive is better, cause I can get more power to the ground and therefore acceleration is better, or at least it is not bader than with a shorter fd.
Perhaps I can convert some rpms for AutoX with smaller tire diameter. And rise the redline about 300rpms to get some speed back again for the straights on autoX.
Perhaps a larger fd is also better for DRAG racing, cause of the better traction?
PS: A 6 gear tranny would be nicer.
Old Jul 10, 2002 | 05:28 AM
Reid's Avatar
Global Moderator
Have you tried simply running taller tires for an increased top speed?
Sure, indicated will be the same, but actual will be greater.
Old Jul 10, 2002 | 05:31 AM
Dr Pooface's Avatar
I think you have enough power that the 300 rpm drop wont bug you. Actually, you'll probably find that staying in the gears longer will feel better. I have the ATS FD, and I drove an R with the stock one on monday. I'm used to redlining 3rd at 120kph. Stock is 140 . I say go fo the USDM FD.
Old Jul 10, 2002 | 05:38 AM
I run now oversized tires 225/45/16.....which have 13mm more diameter than stock and this sidewall is okey for looks and has performance too. Any taler and I have fender rubbings problems, cause my car is lowered.
Yeah, I have the power, but turbo lag sux, I have now no problems with turbo lag on autoX events.
Old Jul 10, 2002 | 06:24 AM
Ex-ITR5874's Avatar
Hu ?
Why running 290 km/h ?? Do it the right way and try to crack the 300kph....
You now exactly, this would be your next goal from that day on you drove 290.....that wouldn`t be enough for you..
Old Jul 10, 2002 | 06:32 AM
DutchITR1689's Avatar
Default Re: special question about speed sensor! (ITR1858)
He wants to break the ITR (street) top speed record.......
Old Jul 10, 2002 | 07:07 AM
Default Re: special question about speed sensor! (DutchITR1689)
what is the ITR top speed record.
Right Sven, I want to do 300+, just raise the Redline from 8800 to 9200 and hello magic 300
Old Jul 10, 2002 | 07:12 AM
Hahaha. It was a joke!!! I think you are now the record holder (for a street car)....
Be careful, have you seen the Mercedes LM CLR on Le Mans?
Old Jul 10, 2002 | 07:17 AM
no
Damn 300+ would be kickin azz!
Old Jul 10, 2002 | 07:32 AM
The mercedes flew up at top speed, flipped over in the air and landed on it's roof!!!
Old Jul 10, 2002 | 07:35 AM
Ex-ITR5874's Avatar
Doesn`t matter if you die young as long as you die happy...
Old Jul 10, 2002 | 07:37 AM
Couldn't find any pictures of that incident, but found this video: http://www.autofolie.org/download.php3?id=216
Hatchman98
Jan 5, 2007 03:34 AM
