can't find redline on JDM B18C1
Old Apr 1, 2008 | 09:45 AM
kakahoya's Avatar
Default can't find redline on JDM B18C1
hello all!
I just picked up my car few days ago and it has JDM B18C1 engine. I was reving it until 8800 to find out fuel cut off and it kept going. I went on to the next gear, because I didn't want to cause any problem.
The previous owner told me, he's using JDM GSR ECU and the redline should be around 8500. Well, I looked up, and it should not rev beyond 8200.
What's going on?
Any advice??
Old Apr 1, 2008 | 09:54 AM
SkaiWu's Avatar
i he increased the redline then? I don't know how to reset it
maybe reset the ecu the same way you would when you install a new header?
i dunno, if someone else can answer also because i also have an increased redline but i never took it past 8.1k
Old Apr 1, 2008 | 10:14 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: can't find redline on JDM B18C1 (kakahoya)
Check the ECU and don't rev that high. The ECu could be programmed wihtout a rev limit, which is bad.
Old Apr 2, 2008 | 04:19 PM
Washingtonboi08's Avatar
Yeaa the ecu has been chipped any honda performance shop can fix that. Or go on ebay and buy a chip thats for your ecu and swap it out for correct vtec kick in and redline
Old Apr 2, 2008 | 06:14 PM
teggsr925's Avatar
Default Re: can't find redline on JDM B18C1 (Washingtonboi08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Washingtonboi08 &raquo;</TD></TR><TR><TD CLASS="quote">Yeaa the ecu has been chipped any honda performance shop can fix that. Or go on ebay and buy a chip thats for your ecu and swap it out for correct vtec kick in and redline</TD></TR></TABLE>
dont go and buy a chip off ebay smh
P@@RB@Y
Nov 17, 2005 06:23 PM
riceball777
Jun 4, 2003 09:46 AM
DC2 12
Aug 14, 2002 08:41 PM
migo
Jan 19, 2002 05:57 PM
