Tranny noise
Old Apr 1, 2008 | 05:30 AM
faxshatch's Avatar
Default Tranny noise
Ok ive had this problem for a while. ive grown accustom to it but if i can fix it that would be great. When i am downshifting from high rpms into a lower gear my tranny makes a howling noise. When im goin along steady in 1rst and left of the gas quick it makes the noise to and it is realy jerky, Any ideas of what it could be? I imagine its a bad bearing right??
Old Apr 1, 2008 | 05:52 AM
mortificationrock's Avatar
Default Re: Tranny noise (faxshatch)
My bet is that its the ISB. Input Shaft Bearing. Does it do it while accelerating? Does it go away when you press in the clutch? If you answered yes to these questions then its your ISB. Its a bitch to change. Need to tear apart the tranny and ****. Best bet buy another tranny or drive it with that anoying winding sound. That's what I do. Till I do my swap.
Old Apr 1, 2008 | 05:56 AM
faxshatch's Avatar
Default Re: Tranny noise (mortificationrock)
Yea im willin to bet that uve hit thenail on the head! thanks. Now do you have an opion on what tranny i should get? Im goin to be boosting my mini me later this sumer so should i get another cx tranny or an y8/z6 tranny. I think my cx would be sik with boost!!
Old Apr 1, 2008 | 06:02 AM
Well that's really a debate. Some people would say the longer gears would be better for boost but, then again I like the short gears of a ex/si tranny. So on my opinion I would drop in a ex/si tranny. Atleast that's what I have on my setup. Turbo also.
Old Apr 1, 2008 | 06:05 AM
faxshatch's Avatar
Yea my thought was that if the turbo was spooling at 3800 rpms that i might get longer boost durations with the cx tranny ut i still think the ex would be quicker.
Old Apr 1, 2008 | 06:15 AM
Well, also take in consideration that it also depends what size turbo you going to run. Smaller turbo's spool faster,therefore you'll probably reach max psi fast enough. On the other hand a bigger turbo will need more time due to that it takes longer to spool. Get the picture? so id say swap a ex/si tranny with a t04 turbo and your good to go. Cuz remember you got one of the longest trannies. I had a lx once too. And it sucked *****.
Old Apr 1, 2008 | 06:20 AM
faxshatch's Avatar
Yea ur makin nuthin but sense so i geuss its time to find a new tranny!!
JaviITR
Jul 31, 2009 10:40 AM
Mike"IAMSLOW"Myers
Feb 24, 2008 02:40 PM
Cwhiteg6
May 30, 2006 03:25 PM
onetrueshyguy
May 6, 2005 09:48 AM
MasterSaif
Mar 15, 2004 08:20 AM
