EF9 conversion to disc brakes
yo do you need the brake booster from the car you take off the disc brakes cause i resentlly converted to disc brakes on my EF but i seems that the brakes are not working to good. i just need help to know if i need something else from the car i took the disc brakes off. like the brake booster?
Modified by sleephondsleep at 2:13 PM 4/1/2008
you are a sad sad little man!
Can you lirn to understand to rite engrish?
Wow
If I read this right? You want to know if you need the brake master cylinder from the donar car to use with the swap on your car?
No
Wow
No
what u need is the propotioning valve from the donor car . the valve distibutes the rite amount of fliud accordingly to the brakes witch is different on your car witch had rear drums. do a search on prop valve or chaek the FAQ section, good luck!!!!
no, you don't need anything to do a disc brake conversion be it the front or rear brakes
you just might need to bleed them a little bit.
you will need two people for that, one to push the brake pedal and one to bleed the brakes
to bleed them, Push down the pedal 6 times and hold it down on the sixth time, have
your friend open the bleed bolt and then close it shut right after
Do this for each brake both front and both rear, to get the brake pressure up again.
This is what the value looks like https://honda-tech.com/zerothread?id=2246277
make sure its a 4040 though!
RB_EJ8
10
Aug 24, 2008 10:41 PM
jasonweaver88
Jun 29, 2007 10:31 AM
