cuts out at 3500rpms. please help
Old Mar 31, 2008 | 07:45 PM
duthie14's Avatar
Default cuts out at 3500rpms. please help
i have a 95 turbo civc with a d16. check engine light is on and the car will not rev past 3500rpm, it is acting like a limiter. can still be drivin but runs like its not getting good spark. it has a weak low idle. Please give me any suggestions.
Old Mar 31, 2008 | 08:07 PM
duthie14's Avatar
Default Re: cuts out at 3500rpms. please help (duthie14)
distributer was recently replaced with msd cap and rotor and since this problem began i have checked plugs, wires and coil and everything seems to be fine.
Old Mar 31, 2008 | 10:38 PM
what code is it throwing???
Old Apr 1, 2008 | 05:41 PM
palmbayeg's Avatar
try the basic reseting the ecu
Old Apr 1, 2008 | 07:55 PM
91DA9's Avatar
Default Re: (palmbayeg)
Yeah check what code it is throwing. It is definitely a major one that is setting the ECU to go into "limp home" mode, hence the rev limiting and the poor performance.
Old Apr 1, 2008 | 08:51 PM
HONDAPARTSMANMIKE's Avatar
ya what code are you throwing? it might be a vtec code check your oil level.
Old Apr 3, 2008 | 04:28 PM
duthie14's Avatar
thanks for the replys i found out what was wrong, it is my ECM.
Old Apr 4, 2008 | 10:27 AM
LastGenEK's Avatar
I had the same problem acts like no power and cuts out. Pull the cat off if you have on and see if that fixes it. I have a 2000 civic ex with a gsr swap and it clogged the cat after 1500 miles
ShagPower
Sep 18, 2006 09:31 AM
PowerHouse
Nov 12, 2004 04:01 AM
SunkistRex
Apr 12, 2004 10:27 AM
GuyInASpeedo
14
Sep 24, 2003 07:34 AM
NawTeeCRX
Jul 22, 2002 01:14 PM
