Interior trim piece removal
Old Mar 31, 2008 | 07:19 PM
rick1574's Avatar
Default Interior trim piece removal
I'm trying to find out how to remove the piece below circled in red. i would search, but i have no idea what its called, and the dash removal threads all have expired pics. so any help would be appreciated.
its that gray trim piece.
Old Mar 31, 2008 | 07:29 PM
92egSnatch's Avatar
Default Re: Interior trim piece removal (rick1574)
i couldnt figure out how to get that piece out either i pryed at it with flat head and it felt like it was gonna break so i left it alone
Old Apr 1, 2008 | 06:41 AM
rick1574's Avatar
Default Re: Interior trim piece removal (92egSnatch)
bump.
someone's had to have taken this thing off before.
Old Apr 1, 2008 | 06:47 AM
hondaon18's's Avatar
its got screws in the back when i tryed to get them off so i just gave up. im thinking you would have to remove the dash to get at it !
Old Apr 1, 2008 | 08:24 AM
93preludeh22's Avatar
Default Re: Interior trim piece removal (hondaon18's)
I don't see any screws or anything..
Old Apr 1, 2008 | 08:43 AM
Luserkid's Avatar
Default Re: Interior trim piece removal (93preludeh22)
Look at number 38 on that diagram theres i believe 3 (off the top of my head). Its really easy to pull with the dash off. If the dash is on, hope your small and limber.
Old Apr 1, 2008 | 10:22 AM
CEMAYHALL's Avatar
You HAVE to remove the dash...
Old Apr 1, 2008 | 11:15 AM
DISROK1's Avatar
remove the dash
Old Apr 1, 2008 | 01:31 PM
Mr Marcin's Avatar
yup you need to remove the dash...its really not bad at all...i pulled the dash out in 15 mins
Old Apr 1, 2008 | 01:35 PM
hondabadtoy's Avatar
Default Re: (Mr Marcin)
yup dash has to come out and its got about 10 screws holding it to the dash. The dash aint hard to get out its about 10-12 bolts. Just make sure u are carefull with your wiring and passenger air bag
Old Apr 1, 2008 | 01:41 PM
allshownogo's Avatar
I think you need to remove some screws on the side above the center and work your way from there they shouldnt be too hard to find. I have mastersheets at work but unfortunatly im not there right now. call 434 817 1000 then type in ext.5500 and you will get the crutchfield technical support line they can tell you
Old Apr 1, 2008 | 04:58 PM
Mr Marcin's Avatar
Default Re: (hondabadtoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabadtoy &raquo;</TD></TR><TR><TD CLASS="quote">yup dash has to come out and its got about 10 screws holding it to the dash. The dash aint hard to get out its about 10-12 bolts. Just make sure u are carefull with your wiring and passenger air bag </TD></TR></TABLE>
airbag isnt hard to take out...just take out the battery and then unplug the one yellow clip to the airbag and one 10mm nut to the airbag right above the glove box....i worried the same way and then when i did it i was like wow
Old Aug 22, 2010 | 09:21 AM
David Thayer's Avatar
hey, i saw your post, well the easyest way i found out to take that trim piece off is get under your dash theirs cut outs specificley for that piece, all u need is an angled phillips,and some major patience. but the A/C cluster is screwed into it, so i ended up breaking mine off and have to take my whole dash out to replace it! and the funny part about this is, this is they only part of the dash thats not a snap or clip on..gotta love JDM...
prolifik22
Nov 10, 2007 01:51 AM
dketsa22
May 29, 2007 10:56 AM
Hondatuner88
Audio / Security / Video
Sep 1, 2006 02:57 PM
neilff
Apr 24, 2003 09:46 PM
