Oil light
I changed my oil about a month ago, and ever since then every time i start the car in the morning the oil light stays on for about 10 seconds and then shuts off, today i noticed it flash before it went off, whats wrong??? The oil level is perfect right in the second dot.....
Modified by Rkrd25 at 9:12 PM 3/31/2008
i think the oil pan is a bit dented but not that much, and it stays on maybe 5 6 seconds not 10, but today it flashed which i had never seen before, thats only one of the many problems this car has............O2 sensor is bad, ABS sensor is bad, it does not go past 4000RPM it just chokes and goes no where but anyways, the oil light is the newest problem, how do i test for oil pressure???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rkrd25 »</TD></TR><TR><TD CLASS="quote">i think the oil pan is a bit dented but not that much, and it stays on maybe 5 6 seconds not 10, but today it flashed which i had never seen before, thats only one of the many problems this car has............O2 sensor is bad, ABS sensor is bad, it does not go past 4000RPM it just chokes and goes no where but anyways, the oil light is the newest problem, how do i test for oil pressure???</TD></TR></TABLE>
Get the other problems fixed asap. You can get an electric oil pressure gauge. The oil pressure sensor behind the block likes to take craps so it might be a faulty sensor.
http://www.clubrsx.com/cr/AUM-4327-p-GFAULE.html
Mr. Samurai
10
Feb 28, 2005 05:59 PM
crexer
Jan 12, 2005 06:12 PM
