Altinator belt?
Old Mar 31, 2008 | 05:25 PM
scspeed's Avatar
Default Altinator belt?
One of my belts are squeaking on my car so i figured i needed to tighten my altinator belt? the squeak goes away after it warms up, somtimes... So i loosend the nut by the power steering and then tighted the wing nut on top. then tightend the nut back down. I did this about three times and it still squeaks. Am i adjusting the wrong belt? or is there somwhere else i can adjust it that wil work better? lmk thx
Old Mar 31, 2008 | 06:35 PM
goodtrouble's Avatar
Default Re: Altinator belt? (scspeed)
Maybe the belt is too tight? IDK or time for a new belt?
Old Mar 31, 2008 | 07:32 PM
mayoforlife2's Avatar
Default Re: Altinator belt? (goodtrouble)
well if that belt is tight then maybe you should try your other belts guessing you have a/c and p/s , that wing nut only tightens p/s , what kinda car do you have?
Old Mar 31, 2008 | 10:19 PM
dude_123's Avatar
If your belts are going out try pouring water on them. If they stop squealing then you found the belt.
Old Apr 1, 2008 | 06:07 AM
lmike6453's Avatar
i have this same sqeaking problem and i believe it is my a/c idler pulley...
when it's sqealing put your ears in between the power steering and water pump area and if you hear it on your left side then you have the same problem as me
Old Apr 1, 2008 | 11:57 AM
scspeed's Avatar
I have a 94 acura integra...and if the wing nut only tightens power streering then where do you tighten the other ones?
Old Apr 1, 2008 | 06:20 PM
lmike6453's Avatar
search on team-integra.net for the timing belt diy under article section...it explains it in there
Hatch0126
Dec 20, 2015 03:06 AM
mclasser
May 24, 2015 10:26 PM
Ajax_Integra
Jun 10, 2013 03:46 PM
holdenw172
Honda Civic (2001 - 2005)
Aug 10, 2009 01:54 PM
MeanGreenEG9
Apr 9, 2003 07:38 PM
