When is the most accurate time to check oil level?
Old Jul 9, 2002 | 10:50 PM
Comptech98GSR's Avatar
Default When is the most accurate time to check oil level?
Cold Engine? After it has fully warmed up? Please let me know, as i usually get my reading after it is warmed up, and let it sit for a few min. to let the oil settle into the pan.
[Modified by Comptech98GSR, 5:03 AM 7/10/2002]
Old Jul 10, 2002 | 03:03 AM
Xsi's Avatar
Xsi
Default Re: When is the most accurate time to check oil level? (Comptech98GSR)
When it's cold and on level ground.
Old Jul 10, 2002 | 03:21 AM
primoEF's Avatar
first thing in the morning
Old Jul 10, 2002 | 04:38 AM
kinesistech's Avatar
Ive seen over 1/2 quart varience with this method. Its no good. Cold engine is best for cars with wet sump.
Old Jul 10, 2002 | 05:12 AM
WOTTEG's Avatar
You are doing it corrctly Comptech98GSR, the engine has to be at operating temperature, and let the oil settle a little.
It tells you in your owner's manual.
Old Jul 10, 2002 | 05:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: When is the most accurate time to check oil level? (kinesistech)
I also prefer checking in the morning. I usually check my oil and tire pressure first thing every Saturday morning.
Old Jul 10, 2002 | 10:33 AM
Default Re: When is the most accurate time to check oil level? (PatrickGSR94)
is anyone a 100% sure as to how to get an accurate reading. B/c i seem to be about 1/4 quart low on oil almost every 900 miles, if not more. Can't understand it, unless i am not reading my dip stick right, but i don't think that is the case.
Old Jul 10, 2002 | 12:54 PM
You need consistency when you check. It has to be the same environment otherwise you may get different readings. Thats why I think morning on a cold engine is good. Its consistently the same conditions.
adamn92
Dec 17, 2012 01:40 PM
TypeRuz
May 12, 2004 12:38 PM
Qwikrex
Dec 11, 2002 03:05 PM
B18Redline
Jun 10, 2002 11:35 AM
corky2k
Sep 15, 2001 07:37 PM
