Which clutch should I get?
Old Jul 9, 2002 | 10:39 PM
Brandon's Avatar
Life is Suffering
Default Which clutch should I get?
I am going to replace the clutch soon and since I will be FI in the near future, I was wondering what clutches you guys have had success with that dont break axles or other drivetrain parts. I also have one other requirement, it has to be streetable so that I wont sprain my ankle after a highway trip home (like with my 924).
Old Jul 9, 2002 | 10:52 PM
JustOneMore's Avatar
Default Re: Which clutch should I get? (accordvtec)
Daikan Exedy, because they make their clutches complete from scratch. Other brands are mostly rebuilds. I was even told that if you scratch off the paint off a ACT clutch, you'll see the Exedy name label on the metal, kinda tells you something. Anyhow, I just bought the Exedy Organic 08-805 for my car and it's great, not too hard, but definitely noticealbe difference in grip. From wut I understand, it's great for street and can hold plenty even if you want FI.
Old Jul 9, 2002 | 10:55 PM
Accord94DX's Avatar
Default Re: Which clutch should I get? (JustOneMore)
well ****..if act is just an "exedy rebuild" its the best damn rebuild i have ever had...
ACT all the way.
Old Jul 9, 2002 | 11:43 PM
badazzaccrd's Avatar
Default Re: Which clutch should I get? (Accord94DX)
You might want to check this out
https://honda-tech.com/zerothread?id=215379
and
https://honda-tech.com/zerothread?id=218506
Old Jul 10, 2002 | 02:25 AM
D16Z6racing's Avatar
Default Re: Which clutch should I get? (badazzaccrd)
Well, I'm on my third tranny w/ an ACT 6 Puck. I'm saving for Clutch Master.
Old Jul 10, 2002 | 02:35 AM
CD8's Avatar
CD8
Default Re: Which clutch should I get? (buster13)
in about a month or so, i will buy purchasing an RPS sport series clutch. im getting the 6-puck sprung hub design. it can handle up to 280 ft lbs torque. im staying NA so that will prolly be pleanty. the way i found out about there clutch is i have a friend building a turbo prelude and he went with their stronger clutch, can handle up to 700hp. ive driven his prelude with that clutch, and i love it. check out there webpage at http://www.turboclutch.com
Old Jul 10, 2002 | 04:28 AM
John's Avatar
New User
I'm using an ACT XTSS... it's awfully stiff, but grabs very very very hard. No clutch chatter at all, and definitely streetable in traffic.
Old Jul 10, 2002 | 07:14 AM
Brandon's Avatar
Life is Suffering
Default Re: Which clutch should I get? (DunReit)
That is way too stiff then. I guess I'll look at the prices for an Exedy clutch (and possibly flywheel). I'll also look at the ones exaccord mentioned.
Old Jul 10, 2002 | 07:51 AM
4doorH22's Avatar
Exedy or Clutchmasters.
Old Jul 10, 2002 | 08:21 AM
Brandon's Avatar
Life is Suffering
Default Re: Which clutch should I get? (4doorH22)
I've heard scary things about Clutchmasters and their friction material. I may end up with an Exedy as long as my Porsche doesnt run me into the ground after I purchase the parts needed to fix it.
Old Jul 10, 2002 | 11:34 AM
CD8's Avatar
CD8
eh, stayaway from clutchmasters... ive had numerous different people tell me horror stories of the way they use refurbished oem materials
Old Jul 10, 2002 | 11:37 AM
John's Avatar
New User
Default Re: Which clutch should I get? (exaccord)
I initially bought the Clutchmasters Stage 3, but sold it on eBay after hearing some mixed reviews. If I was going to do it all over again, I'd probably get an Exedy.
Old Jul 10, 2002 | 12:44 PM
smokin rubber's Avatar
I have the CM stage one and CM flywheel, no complaints, grips great but I've only had it for five months.
Old Jul 10, 2002 | 08:13 PM
HidPerf's Avatar
Default Re: Which clutch should I get? (smokin rubber)
I'm running a Clutch Net Modified pressure plate and Carbon Fiber/Kevlar disc with a Fidanza flywheel. So far no problems. Not to stiff, not to grippy.
I had a Clutch Specialties HyperClutch. 6-puck, sprung hub. Biggest POS clutch in the world. On my stock F22, it didn't last a year!!! And I was EASY on it.
EK k kay
Apr 17, 2006 08:55 AM
91integraLSVTEC
Sep 13, 2003 12:43 AM
ahead
Nov 18, 2002 02:59 PM
