92-95 civic cowl hood
Old Mar 31, 2008 | 09:14 AM
95Coupes's Avatar
Default 92-95 civic cowl hood
Does anyone know if they make a cowl hood for a 92-95 civic coupe, and if so who and where. All help appreciated.
Old Mar 31, 2008 | 11:54 AM
95Coupes's Avatar
Default Re: 92-95 civic cowl hood (95Coupes)
Any one?
Old Mar 31, 2008 | 12:30 PM
Natedawg241's Avatar
Google> Civic cowl hood
but why?
Old Mar 31, 2008 | 12:38 PM
honduh_head's Avatar
i think this is what you are looking for:
http://www.cervinis.com/search.aspx?make=Honda
but, they don't have them for the Eg's...BUT. get one for an Ek and make it fit
Old Mar 31, 2008 | 12:42 PM
Hurleystrcr9621's Avatar
Default Re: (honduh_head)
I agree with Nate on this one... Why? But hey it's your car, start with google, maybe andysautosport.com, if they are even still around
Old Mar 31, 2008 | 01:03 PM
95Coupes's Avatar
Default Re: (Hurleystrcr9621)
i saw they had them for the ek's thats why i was wondering if anyone knew who made one for an EG
Old Mar 31, 2008 | 01:11 PM
blk92_d16's Avatar
I've seen a FG one up on Ebay before...but not sure if it's still there.
Old Mar 31, 2008 | 03:23 PM
spock_rocker's Avatar
memoryFAB.com representative
ive seen pictures of the hood your thinking of in adds from magazines like 7-8 years ago but i really dont see why.. there so BAD and not in a good way
Old Mar 31, 2008 | 10:55 PM
stripes777's Avatar
u can jus put 3 washers where the hood bolts on and your hood would be raised! same heat passage idea for 3 bucks!
Old Apr 1, 2008 | 01:36 AM
SuperSonikBluEK's Avatar
Default Re: (stripes777)
Old Apr 1, 2008 | 02:52 AM
1992Si's Avatar
Save your money. Or spend it on something that will make the car perform better.
Old Jan 31, 2011 | 08:21 AM
birdogg27's Avatar
I need a cowl hood for a 95 EG sedan to clear the LS swap I put in. It sits a cople inches higher and now the hood rests on the engine when its closed. I DO NOT want to do a front end conversion to make a EK hood fit either.
Old Jan 31, 2011 | 09:22 AM
singlecammin's Avatar
If it sits higher than you've done something wrong
Old Jan 31, 2011 | 09:41 AM
TwoFaced's Avatar
Make one?
http://www.amazon.com/Lund-80005-Tru.../dp/B000COL53K
If you use hood spacers and cut out the metal supports will it not fit? Is it on the valve cover itself or just the intake that's having clearance issues?
Old Jan 31, 2011 | 10:16 AM
grumblemarc's Avatar
The Grumpiest
3 year old thread.
Old Jan 31, 2011 | 10:19 AM
TwoFaced's Avatar
Lol...I didn't even catch that.
Old Jan 31, 2011 | 10:27 AM
Former User's Avatar
^But birdogg has now posted a related question in post #12. Please respond to him if you have an answer.
Old Jan 31, 2011 | 10:58 AM
The Grumpiest
I thought I gave an answer. The issue is not the hood. You need figure out why your swap, which seems to be pretty common, is having issues when no one else seems to be reporting clearance problems. Are you using some odd mounts or something?
Old Jan 31, 2011 | 11:07 AM
Nope:
3 year old thread.
Old Jan 31, 2011 | 11:46 AM
TwoFaced's Avatar
As I mentioned above...making your own hood can be simple if you have, or know somebody who has some decent body work skill. Get a universal cowl hood scoop that has dimensions that would fit your hood...mock it up...measure twice...cut once...secure it down...and if you want a super smooth look use fiberglass or related fillers till you get the desired effect. Paint...enjoy.
It does seem odd that this swap wouldn't fit...and to repost my last question...is it valve cover clearance or intake manifold clearance?
Old Jul 24, 2011 | 12:32 PM
highmfer's Avatar
I hate to revive an old thread, but....my issue IS the valve cover hitting the webing on the under side of the hood. I AM using stock EG mounts (using trans, timeing and rear rocker mounts) w/ B16a2 in my 92 VX. I am wondering if any one has tryied cutting the USDM oem hood "bump" and making it a little higher(1/4 - 1/2''). The reinforcing webbing would oviously have to go w/ the "bump" or be modified some other way to make the clearance.
Side note: my hood will close, but if slammed it dents the webbing and I don't want to have a running car but a working car. Thanks in advance....even for the smart *** answers too.
0.o slow 1.6
Sep 7, 2007 08:35 AM
bnuk013
Aug 21, 2007 04:28 PM
.:Made in OC:.
Jun 6, 2007 02:29 PM
