Electrical 95 accord 5sp
Old Mar 31, 2008 | 09:00 AM
bloodyknuckledad's Avatar
Default Electrical 95 accord 5sp
This probably will be a "is he Kidding" for some.
I just picked up a 95 Accord, 5sp that was a basket case tuner car. The previous owner stored it only to have someone break in and try to steal the car but settled the electronics.
The wires were cut, hacked, chewed on so the entire wire harness is being replaced then the after market components put back in properly.
There is one thing that is driving me nuts, I am trying to mount a module (metal case with a funky L bracket with a hook) somewhere on the driver side next to the clutch pedal ... where does it mount since it does not look like it fits like my auto 94 VTEC Accord.
Images would be appreciated.
Any insight also would be appreciated.
Thanks!
Old Apr 1, 2008 | 04:29 PM
Default Re: Electrical 95 accord 5sp (bloodyknuckledad)
Forget it, it is the cruise control module, they hacked and whacked the mounting points... I relocated.
Old Dec 11, 2010 | 01:18 PM
I have another question on another Accord, this one is a LX non-vtec auto no ABS and this one is for my other daughter. This one the previous owner melted the wire harness using HID lights and the wrong fuse. I am in the process of replacing it, 90% there with 1 issue. I pulled another wire harness from the auto recycling yard and there are 2 differences, the new one had abs which didn't seem to be a problem however it looks like there are 3 plugs that look like they go to a TPS blue and Grey to Map sensor?? The only open plug is for the pump that goes to the fuel vapor canister and these do not fit. I would prefer not to pull the the harness I have 90% finished back out.
pos95accord
Sep 5, 2006 04:31 PM
ashish_bhatta
Dec 21, 2001 09:32 AM
