TIRED OF SEEING CHECK ENGINE LIGHT
Old Mar 31, 2008 | 04:40 AM
91BlueEF9's Avatar
Default TIRED OF SEEING CHECK ENGINE LIGHT
Hey guys. Okay, so i am officially frustrated with this. About two weeks ago, my car started throwing CEL. I found out it was code 9 which is Cylinder Sensor (CYP). So I looked up previous threads before posting a new one and found a few things out. First, I was using an MSD Dizzy with External Coil, and someone said they tend to make your car throw CEL, but I'd had it on there for about 5 months with no problems, so someone said to do a new Cap and Rotor. Done, still CEL. Then, I read you need to change out the entire Dizzy, so I got a BRAND NEW OEM one, once installed, CEL didn't even hesitate to pop itself right back on. I'm at a loss now and don't know what I should do. Its an OBD1 completely converted from OBD0 from RyWire. I also saw that I should check my wiring. Came to find out that one of the Dizzy pins was loose, fixed that and CEL was gone for about 24 hours, then came right back, checked again and they were fine, now what? Keep in mind, I got it tuned and they had to bump the timing, its completely advance...could that be it? Should I try doing the timing and setting it to TDC? Thanks in advance for any help you guys may be able to provide, anything will help at this point...
Old Mar 31, 2008 | 09:02 AM
grog's Avatar
Default Re: TIRED OF SEEING CHECK ENGINE LIGHT (91BlueEF9)
did you pull the hazard/ecu fuse to reset the ecu when you did this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91BlueEF9 &raquo;</TD></TR><TR><TD CLASS="quote"> I got it tuned and they had to bump the timing, its completely advance...could that be it? Should I try doing the timing and setting it to TDC? </TD></TR></TABLE>
IDK possibly, try setting it to 16 degrees.
Old Mar 31, 2008 | 10:29 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: TIRED OF SEEING CHECK ENGINE LIGHT (grog)
pull the bulb in the cluster, problem fixed!
Try what grog said then report back.
Old Mar 31, 2008 | 10:38 AM
91BlueEF9's Avatar
Default Re: TIRED OF SEEING CHECK ENGINE LIGHT (***$nyper)
I pulled the fuse and disconnected the battery every time I tried something new. I just tried pulling the fuse without disconecting the battery and it still comes on. I was thinking of pulling the bulb, but I forgot now I have the CEL Shift Light on there from the tune...
Old Mar 31, 2008 | 01:37 PM
Tippyman's Avatar
PM me your e-mail address and I will send you the troubleshooting flowchart for a code 9.
Old Mar 31, 2008 | 02:43 PM
DeeJayCrx's Avatar
i had this code before check all your wires on the rywire harness one came loose on mine
jst17
Acura TSX
Mar 25, 2014 06:16 AM
6KAOS6
Jun 4, 2011 05:55 AM
TypeR324
Honda S2000
May 8, 2009 01:30 PM
TypeR324
Honda S2000
17
Apr 15, 2009 09:42 AM
raCeRX_88
Nov 22, 2005 06:06 PM
