What do i need to tune a car *Newb*
I have stock ecu from a 00 civic. running a edelbrock piggyback ecu, i was thinking out taking it off and go with hondata or crome. What will i need, from what i know is that all i need is a jumper wire harness (obd2-obd1) and a tuning system. do i need anything else?
From: New York in the summer, South Carolina in the winter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civic ex »</TD></TR><TR><TD CLASS="quote">I have stock ecu from a 00 civic. running a edelbrock piggyback ecu, i was thinking out taking it off and go with hondata or crome. What will i need, from what i know is that all i need is a jumper wire harness (obd2-obd1) and a tuning system. do i need anything else? </TD></TR></TABLE>
First off- do you want to tune it yourself? or do you want to take it somewhere and let a professional tune it? Where are you located? check out the tuner directory at the top of the FI section- itl help ya out trust me lol
anyways since your car is OBD2, your going to need a harness to go from OBD2 to OBD1- Secondly your going to want a P28 ecu from a 92-95 civic ex/si- Auto or manual doesnt matter with a competant ecu tuner he can convert it over to manual in about 30 seconds.
He will then chip the ecu, create a basemap onto a chip, and put it in. then using a wideband he will monitor engine parameters and create a new chip over and over until its perfect.
I would HIGHLY recomend just taking it to a tuner and having them do it- the initial costs are going to be upwards of 500 dollars for you, and you can really hurt your engine. A good tune will cost you about 500 but its going to be much better, as well as less stressful for you.
hope that helps..
hope that helps..
G-Robinson
10
Feb 28, 2008 12:38 PM
1.8
Feb 25, 2005 01:09 PM
