Teaser Pics...
Old Mar 30, 2008 | 05:52 PM
Ben-NSI's Avatar
Default Teaser Pics...
designed for:
2nd harmonic at 9500
3rd harmonic at 7300
4th harmonic at 5500
plenum volume is ideal for an engine displacement of 2 liters
throttle body is 90mm (Q45)
Old Mar 30, 2008 | 08:21 PM
boost_aholic97's Avatar
Default Re: Teaser Pics... (Ben-NSI)
quite the tease! this looks very well thought out!
Old Mar 31, 2008 | 06:12 AM
Running925's Avatar
one word comes to mind!
Amazing!
Old Mar 31, 2008 | 08:34 AM
newby_j's Avatar
Needs More Cowbell
Looks good!
Old Mar 31, 2008 | 09:43 AM
b16_DIM's Avatar
What is a Harmonic? How do you calculate what Plenum volume should be? Hope you don't mind the questions
Old Mar 31, 2008 | 07:08 PM
wed3k's Avatar
looks bitchin.
Old Apr 1, 2008 | 04:21 AM
Ben-NSI's Avatar
Default Re: (wed3k)
A harmonic is the point that a pressure pulse i is reflected back into the runner in time with the opening of the intake valve. Plenum volume is much simpler there is no exact correct volume making it smaller or bigger is a compromise. The rule of thumb is between 1 an 2 times engine volume mine is over 4000cc's so its on the large side which is better for power but worse for throttle response and spool
Old Apr 1, 2008 | 04:56 AM
weiRtech's Avatar
OG Fabricator
couldn't you design a plenum shape that helps increase throttle response and spool but does not compromise power by being too small? i have a couple ideas, but would not be able to prove them without building a prototype and testing it, but i'm confident it can be done.
you have obviously put a lot of thought into this project.
Old Apr 1, 2008 | 05:12 AM
Ben-NSI's Avatar
Default Re: (weiRtech)
sure just make it variable volume, other than that the short answer is no
Old Apr 1, 2008 | 06:20 AM
weiRtech's Avatar
OG Fabricator
by "variable volume" do you mean tapered? i want the long answer!
Old Apr 1, 2008 | 08:35 AM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben-NSI &raquo;</TD></TR><TR><TD CLASS="quote">designed for:
plenum volume is ideal for an engine displacement of 2 liters</TD></TR></TABLE>
Calculating the Helmholtz resonance is easy, but how did you determine the "ideal" plenum volume? I've studied intake design for years and I have never seen a proven formula for the perfect size, just ballpark guidelines and minimum sizes.
Please share the methodology for finding the "ideal" size.
Old Apr 1, 2008 | 09:17 AM
b16_DIM's Avatar
Default Re: Teaser Pics... (Top Ramen)
When you calculated Plenum volume did you include or exclude the volume of the runners inside the plenum? Thanks, this is great info
Old Apr 1, 2008 | 02:33 PM
Ben-NSI's Avatar
Default Re: Teaser Pics... (b16_DIM)
my calculation did not include the bells in the manifold as those are part of the runners and not part of the plenum
Old Apr 1, 2008 | 03:00 PM
-RedneckDave-'s Avatar
Working
I would also like to know how you figured this to be the ideal size.
Old Apr 1, 2008 | 04:31 PM
all_motor_mike's Avatar
Default Re: Teaser Pics... (-RedneckDave-)
what ever fits in the engine bay is the ideal size.............. actually that holds true with alot of stuff people make because some of the stuff u come up with using that theory is rediculous and would not fit very well.
mike
Modified by all_motor_mike at 9:40 PM 4/1/2008
Old Apr 1, 2008 | 07:50 PM
jeffy's Avatar
Default Re: Teaser Pics... (all_motor_mike)
looks real nice. i thought it was good looking and then i noticed it was an s2k, and now its better!
Old Apr 1, 2008 | 08:35 PM
9bells's Avatar
OG Fabricator
Default Re: Teaser Pics... (jeffy)
Looks great!!!
9500rpm, nice!!!
Old Apr 2, 2008 | 01:39 AM
140sx's Avatar
would a manifold like this work well for FI. if so sign me up i need one.
Old Apr 2, 2008 | 02:41 AM
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">what ever fits in the engine bay is the ideal size.............. actually that holds true with alot of stuff people make because some of the stuff u come up with using that theory is rediculous and would not fit very well.
mike
Modified by all_motor_mike at 9:40 PM 4/1/2008</TD></TR></TABLE>
I agree with that. I would like to see the use (on a honda engine) of the dual plenum manifolds that can be seen on Audis.
Old Apr 2, 2008 | 05:15 AM
silver-16v's Avatar
sweet
Old Apr 2, 2008 | 05:26 AM
Ben-NSI's Avatar
Default Re: Teaser Pics... (silver-16v)
its specifically for FI applications although it would work well on NA setups as well
Old Apr 2, 2008 | 08:35 AM
Working
I still would like to see your long answer.
Old Apr 2, 2008 | 09:09 AM
weiRtech's Avatar
OG Fabricator
i called dibs on the long answer a few posts up... i'm always interested in learning theory on this stuff.
Old Apr 2, 2008 | 10:51 AM
Justin Olson's Avatar
Why are the velocity stacks protruding so much into the plenum? Seem a bit like overkill to me. The air that flows behind the stacks will have trouble getting into the runners.
Justin
Old Apr 2, 2008 | 10:55 AM
Default Re: (Justin Olson)
i too was thinking they were sitting a bit high.............. usually u want them about 3/4" at most of the plenum floor because thats where ur fast moving air is........... or so ive heard.
mike
