battery relocation with mastercutoff switch wiring
Can someone give me straight forward wiring diagram for this...I did a search and some guys have wiring going everywhere...I don't want it to look like a rat's nest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">contact tony1 on his kill switch kit. So much nicer and easy to install. </TD></TR></TABLE>
COOL Thanks ART!!!
COOL Thanks ART!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale »</TD></TR><TR><TD CLASS="quote">I did mine.
Start and Alt to pos
pos to switch
switch to everything else</TD></TR></TABLE>
thats it in the nut shell.
pos to switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 0 3 »</TD></TR><TR><TD CLASS="quote">Can someone link me to this switch ? Or show some pictures...
I cant find it on the T1 store site. What make it so simple, does it come with wirring?</TD></TR></TABLE>
me too
me too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy »</TD></TR><TR><TD CLASS="quote">
me too</TD></TR></TABLE>
pic from T1:
pic from T1:
It wires up just like a relay. We usually mount them right near the battery. Power from the battery to one big post. Jump that to one small post. Power from the other big post out to everything getting power. Run a small ground trigger wire to a switch on the rear of the car, out of the switch to a chassis ground. The alternator will need to wire to the post closest to the battery or to the battery positive directly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">It wires up just like a relay. We usually mount them right near the battery. Power from the battery to one big post. Jump that to one small post. Power from the other big post out to everything getting power. Run a small ground trigger wire to a switch on the rear of the car, out of the switch to a chassis ground. The alternator will need to wire to the post closest to the battery or to the battery positive directly. </TD></TR></TABLE>
You Sir are the freakin man!!! T1 for president!!!
depending on hour your car is wired, and where you want to put the solenoid......there are 2 studs under the dash in EG's and DC2 integra's that fit the solenoid perfectly. just add 2 nuts and your done. dont even have to make a bracket. def. easier mounting it near the battery though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">depending on hour your car is wired, and where you want to put the solenoid......there are 2 studs under the dash in EG's and DC2 integra's that fit the solenoid perfectly. just add 2 nuts and your done. dont even have to make a bracket. def. easier mounting it near the battery though</TD></TR></TABLE>
mine car still has factory wiring where are these studs you speak of?
under teh dash on the firewall, close to the center of the car, up top. 2 12mm head nuts i believe. i dont remember what the studs are for if there is still factory stuff under the dash
damnt ive been doing it that way for years new i should of tried to sell some kind of kit
the only problem ive found is to make shure the relay is wired threw the key switch or it will drain the battery in a few days
smokin rubber
Jul 21, 2003 10:34 AM
