Best way to tap into my valve cover for oil catch.
Old Mar 30, 2008 | 04:01 PM
scspeed's Avatar
Default Best way to tap into my valve cover for oil catch.
I need to put 90 degree fittings into my valve cover and dont want to weld becouse it was just freshly powdercoated. I was thinking eather prilling a hole and tapping it adn using a hole bunch of teflon tap. eather that or drill a gold just a little bigger than the treds so i can put it in with a rubber washer on each side adn then hold it there with a thin nut on the other side...what do you think i should do? is there an easyer way? lmk
THX
Old Mar 30, 2008 | 06:05 PM
Akalima's Avatar
Default Re: Best way to tap into my valve cover for oil catch. (scspeed)
Im curious too the oiul from the frost plugs to the catch can sucks ***. The valve cover is the way to go!!
Old Apr 1, 2008 | 11:59 AM
scspeed's Avatar
Default Re: Best way to tap into my valve cover for oil catch. (Akalima)
bump?
Old Apr 1, 2008 | 12:41 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed &raquo;</TD></TR><TR><TD CLASS="quote">I need to put 90 degree fittings into my valve cover and dont want to weld becouse it was just freshly powdercoated. I was thinking eather prilling a hole and tapping it adn using a hole bunch of teflon tap. eather that or drill a gold just a little bigger than the treds so i can put it in with a rubber washer on each side adn then hold it there with a thin nut on the other side...what do you think i should do? is there an easyer way? lmk
THX</TD></TR></TABLE>
I don't think tapping would work, but I could be wrong. The rubber O-ring idea is a decent idea...but how are do you plan on getting the nut on the back side? The baffling will be in the way. Plus I wouldn't want a nut to accidentally come off of there when pieces are moving at 8-9000rpm.
Old Apr 1, 2008 | 06:22 PM
scspeed's Avatar
i actualy just thought about that too...plus the baffling is revited on so it would be super hard to get off. I think the best thing to do it so tap it...maby use a shitload of teflon tape b4 threding it in? idk. at least ill have my old valve cover i can practive on adn see if its gunna work. if you have any other ideas plz lmk THX
Old Apr 1, 2008 | 07:24 PM
Dunc's Avatar
BCICAN
Default Re: (scspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed &raquo;</TD></TR><TR><TD CLASS="quote">i actualy just thought about that too...plus the baffling is revited on so it would be super hard to get off. I think the best thing to do it so tap it...maby use a shitload of teflon tape b4 threding it in? idk. at least ill have my old valve cover i can practive on adn see if its gunna work. if you have any other ideas plz lmk THX</TD></TR></TABLE>
Holy crap one of those Google ads on here was actually useful! Look at what popped up at me when I was reading your reply: Click here for your solution
Old Apr 1, 2008 | 07:30 PM
berb_15's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
Holy crap one of those Google ads on here was actually useful! Look at what popped up at me when I was reading your reply: Click here for your solution </TD></TR></TABLE>
that's for repairing damaged threads...
I think if you're not going to weld a fitting in there you may encounter problems in the future... that metal is pretty thin to be tapping into and may not really hold a threaded fitting for too long. It may work but I'm not sure if I'd personally go that route.
Old Apr 1, 2008 | 07:37 PM
Dunc's Avatar
BCICAN
Default Re: (berb_15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berb_15 &raquo;</TD></TR><TR><TD CLASS="quote">
I think if you're not going to weld a fitting in there you may encounter problems in the future... that metal is pretty thin to be tapping into and may not really hold a threaded fitting for too long. It may work but I'm not sure if I'd personally go that route.</TD></TR></TABLE>
I agree that tapping it isn't the best becuase of the thin metal. But if he does tap it those would work since start with no hole is the same as starting with a stripped out hole.
Old Apr 2, 2008 | 03:50 AM
scspeed's Avatar
Thx guys i think ill try the tap...i have the old valve cover so i will practice on that. anything i should look for or test when i tap the old one?
Old Apr 2, 2008 | 04:32 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed &raquo;</TD></TR><TR><TD CLASS="quote">Thx guys i think ill try the tap...i have the old valve cover so i will practice on that. anything i should look for or test when i tap the old one?</TD></TR></TABLE>
Just make sure you get all the shavings out when you're done. Other than that, just make sure the tap is in straight (but that's obvious)
Old Apr 2, 2008 | 02:36 PM
Akalima's Avatar
Default Re: (Dunc)
what kind of metal is the valve cover. Wondering cause of the different way fittings will be welded onto the unit.
Old Apr 2, 2008 | 06:35 PM
grundle's Avatar
Default Re: (Dunc)
those threaded inserts wont work any better then just tapping the cover. your fittings won't strip out of them, but they still require threads to stay in. I use them alot where i work. They are only for when you strip out the threads in a hole and you need to repair them while still using the original bolt size. the prosses is, drill out the stripped hole to the larger insert size tap the new hole with the thread size of the insert then, thead in the insert then, thread the original bolt in to the insert.
Old Apr 2, 2008 | 06:38 PM
berb_15's Avatar
Default Re: (grundle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grundle &raquo;</TD></TR><TR><TD CLASS="quote">those threaded inserts wont work any better then just tapping the cover. your fittings won't strip out of them, but they still require threads to stay in. I use them alot where i work. They are only for when you strip out the threads in a hole and you need to repair them while still using the original bolt size. the prosses is, drill out the stripped hole to the larger insert size tap the new hole with the thread size of the insert then, thead in the insert then, thread the original bolt in to the insert.</TD></TR></TABLE>
scspeed
Welding / Fabrication
Apr 2, 2008 06:30 AM
scspeed
Mar 6, 2008 04:02 AM
aleks77
Jul 11, 2007 04:49 AM
d16dcoe45
14
Aug 6, 2006 03:12 PM
vtec.dc2
Aug 1, 2006 05:03 AM
