b20 ek swap help!!!!!
when i put my b20 into my ek 98 every thing worked out great except 1 thing the engine is at a tilt the drivers side is lower than the passengers side. i taught the si mount and ex mount on th drivers side was the same has anyone had this problem and if so how did u fix it???????
you used the B20 bracket that attaches to the engine under the timing belt. you need to get a 99-00 si driverside mount that attaches to the engine. the b20 mount is about 2 inches taller than the si mount!
chad
chad
