Blower Stopped Working?
My REX was sitting for some time, and when I went to run it again I had to jump start it. I accidently grounded the battery and blew a couple fuses. I replaced all the fuses, and now everything works exept my blower/heater. If I push the buttons on the climate control I can see the little arms moving to change the vent settings, but I cannot get air to come out of the vents (doesnt make any noise either)
Any help? Thanks!
Any help? Thanks!
If your blower motor is shot, you can replace it easily. I replaced mine with a wrecker unit a couple years ago. You can pull it out from behind the glovebox from underneath. The only other thing that I can think of that could be the problem is the blower resistor but when that goes you usually have at least the highest blower setting still working.
technine
Sep 16, 2002 01:28 PM
