Honda S2000 Honda S2000
Turbo S2000 / Exhaust ?
Old Mar 30, 2008 | 05:46 AM
x4thGenCafe's Avatar
OF THE KINGS
Default Turbo S2000 / Exhaust ?
Just wondering some exhaust you guys are running on your turbo s2k's
My Girlfriends dad just bought one and he plans on boosting it in the near future and really has no clue about parts for s2000's since hes been a domestic guy forever.
Took him for a ride in my hatch and Loved him some VETACKKKK
any help on suggestions and or pictures would be appreciated
Thanks
Old Mar 30, 2008 | 06:28 AM
megalomaniac001's Avatar
Default Re: Turbo S2000 / Exhaust ? (x4thGenCafe)
open downpipe
Old Mar 30, 2008 | 07:17 AM
papa5murf's Avatar
T1R 70mm single.
Old Mar 30, 2008 | 01:40 PM
91jdmhatchback's Avatar
Default Re: Turbo S2000 / Exhaust ? (papa5murf)
custom dual is what i'm doing.
Old Mar 30, 2008 | 01:52 PM
bigmacnfries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">T1R 70mm single. </TD></TR></TABLE>
when i was reserching what exhaust to get - this one came up again and again
or anything big and single from J's...
Old Mar 31, 2008 | 11:43 PM
Basskika's Avatar
Banned
Default Re: Turbo S2000 / Exhaust ? (bigmacnfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigmacnfries &raquo;</TD></TR><TR><TD CLASS="quote">
Anything big .. single / dual. Obviously a single will be more free flowing than a dual but a dual will suit it perfectly if you want to keep the 'stock' look. Berk came up with a 56mm twin pipe dual which they claim is more free flowing than an 80mm single ... might be worth checking out when the time comes to go FI
Old Apr 1, 2008 | 01:01 AM
Junior Wock's Avatar
Default Re: Turbo S2000 / Exhaust ? (Basskika)
also single is louder then dual. any exhaust will work for turbo s2ks.. apexi etc
Old Apr 1, 2008 | 03:47 AM
HondaKyle's Avatar
single 3 inch turbo back HKS Ti hi power...
Old Apr 1, 2008 | 04:38 AM
SwampThing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Basskika &raquo;</TD></TR><TR><TD CLASS="quote">
Anything big .. single / dual. Obviously a single will be more free flowing than a dual but a dual will suit it perfectly if you want to keep the 'stock' look. Berk came up with a 56mm twin pipe dual which they claim is more free flowing than an 80mm single ... might be worth checking out when the time comes to go FI</TD></TR></TABLE> more free flowing is not always a good idea. there are some people on s2ki that are running into problems with this on greddy kits. running test pipes and 70mm exhaust is causing alot of over boost at WOT.
Old Apr 1, 2008 | 04:40 AM
HondaKyle's Avatar
Default Re: Turbo S2000 / Exhaust ? (SwampThing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote"> more free flowing is not always a good idea. there are some people on s2ki that are running into problems with this on greddy kits. running test pipes and 70mm exhaust is causing alot of over boost at WOT.</TD></TR></TABLE> true true... turbos need some back pressure...
Old Apr 1, 2008 | 04:45 AM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering some exhaust you guys are running on your turbo s2k's
Thanks</TD></TR></TABLE>
Custom, or Amuse R1000
Old Apr 1, 2008 | 04:53 AM
papa5murf's Avatar
More free flowing on the S2000 is definitely better. Think about the problems with the Greddy Kit, it's a basic low HP turbo kit for your average/little to no knowledge of car enthusiasts. Also look at the turbo that is run with that setup. It's probably not even able to create much more pressure as it is, so a huge exhaust could cause a bit of problems. But how many people out there get the Greddy Kit to actually make power? Not too many, and if there is one, he/she hasn't done their research.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote"> true true... turbos need some back pressure... </TD></TR></TABLE>
It is true that every car, regardless if it's a turbo or not needs a bit of back pressure. However, it's a bit different on the S. The head of the S already flows so much air it's unbelievable (this is why it revs so quickly, and even lag on a bigger sized turbo is minimal). We have already seen the most gains with a 70mm exhaust on an NA car. Then think about more air flow from a turbo setup, you're going to create even more backpressure, and too much back pressure is not good. A 70mm header back or a 3inch exhaust is a must have if you want to make some serious power.
SwampThing's Avatar
some of the people are running known restrictive exhausts with a TP with good results, but people who run a TP and a known free flowing exhaust are getting boost ranges from 7PSI (thats what they are running) up to 11 and 12 at wot.
Old Apr 1, 2008 | 04:55 AM
SwampThing's Avatar
</TD></TR></TABLE> yeah i know that too, but since he didnt state which turbo kit he will run and alot of people who just want to say, "i have turbo" end up getting the greddy it seems. thats why i said what i said.
Old Apr 1, 2008 | 04:59 AM
papa5murf's Avatar
Default Re: (SwampThing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote">some of the people are running known restrictive exhausts with a TP with good results, but people who run a TP and a known free flowing exhaust are getting boost ranges from 7PSI (thats what they are running) up to 11 and 12 at wot.</TD></TR></TABLE>
That's called tuning issues. Not setup/exhaust issues.
Old Apr 1, 2008 | 05:07 AM
SwampThing's Avatar
Default Re: (papa5murf)
That's called tuning issues. Not setup/exhaust issues. </TD></TR></TABLE> well s2ki sucks then. ignore all previous comments.
persianstud
Honda S2000
13
Dec 29, 2006 07:41 PM
95_red_dc
Nov 22, 2006 02:44 PM
blkSi
14
Aug 7, 2005 04:24 PM
igo4bmx
Apr 22, 2005 01:26 PM
EKB18BPR3
May 6, 2003 01:14 PM
